Old 08-28-2005, 09:11 PM   #1
Wicked Sensation
Front Shock Suggestions
Alright guys its been a few years since I have posted here. I am starting to work on my truck again, and have the front suspension apart now. What I need is some front shock suggestions. My truck is a 76 stepside. I'm not sure of the drop, but it is in the neighborhood of 5"/7". It has drop spindles and springs. So, what are you running for front shocks now adays? Part numbers are welcomed... TIA
Mike
76 Chevrolet Stepside- 402 BBC, pro street
95 S10 2.2 Bagged
67 F100 352/3 speed
72 Nova 307- 30,000 original miles
Wicked Sensation is offline   Reply With Quote
Old 08-30-2005, 11:19 AM   #2
Zilverado
Zilverado's Avatar
My truck is not lowered, but I just installed “Monroe Sensi-trac” shocks a couple of years ago. The existing ones were pretty worn. I have not had the shocks that long, but they seem pretty good – far better than what was there.
I went for Monroe because they are a recognizable brand name and reasonably affordable. Not too much more going into that decision...
Zilverado is offline   Reply With Quote
Old 08-30-2005, 02:54 PM   #3
MM in NM
If you're anything like me, I keep my trucks forever. Go to Sears and get their preminum lifetime gaurantee shocks. I'm on my third pair (after almost 20 years) on my 76 K20 and about to get the second free pair on my 79 C20.
Show them what you have, or what you need since you're dropped, and they'll fix you right up.
Unless you're racing or have some other special needs any quality shock is about as good as any other,, at least I can't tell the difference running on the street.
Never had a problem with Sears. Bring in my nasty looking old shocks and they just give me a new pair whenever I feel the need..
MM in NM is offline   Reply With Quote
Old 08-30-2005, 05:29 PM   #4
SCOTI
SCOTI's Avatar
Sears used to use brand name shocks (from Maremont) years ago. They were the same thing as Monroes.
For my 74, I used off the shelf front Gabriel VST gas shocks. They ride decent & have worked well so far even w/my amt of drop. I did add upper shock relocators to optimize the travel length.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-30-2005, 07:55 PM   #5
laynlow77
can you either send me pics of those upper shock relocators or tell me how you did them? i really need to do something like that to mine!
laynlow77 is offline   Reply With Quote
Old 08-30-2005, 10:12 PM   #6
SCOTI
SCOTI's Avatar
They're pretty simple. Here's basically what I used (the pic is from AirRides catalog in their brackets section). I think they go for $10 each from AirRide but I made mine from 2" square thick-wall tubing. I cut the basic shape & measured/drilled the holes for the bolts. I drilled a hole higher up on the frame rail than the stock shock location & bolted them in. They've been on there for 3yrs now w/o any problems. I gained about 2" of travel.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-30-2005, 11:31 PM   #7
laynlow77
you wouldnt happen to have i picture of yours would you? im having trouble seeing it!
Old 08-30-2005, 11:36 PM   #8
SCOTI
SCOTI's Avatar
This is the pic from the 03 Tx Heatwave show in Austin. I was right across from N2TRUX's black 77 & went un-noticed.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-30-2005, 11:55 PM   #9
laynlow77
wow that thing is nice....so is n2trux i was talking about the upper shock mount lol.....do you have a picture of that? im not seeing how it goes in my head
Old 08-31-2005, 12:13 AM   #10
SCOTI
SCOTI's Avatar
Yeah . . .... I knew that but it's dark outside so this is the only pic for tonight . I'll get you one of the relocated shock mount tomorrow.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-31-2005, 09:27 PM   #11
SCOTI
SCOTI's Avatar
Pics as promised . . .....
A side shot
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-31-2005, 09:28 PM   #12
SCOTI
SCOTI's Avatar
And another . . .....
This is from the back off the truck looking forward.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-31-2005, 09:30 PM   #13
SCOTI
SCOTI's Avatar
Last one . . .....
And from the front 3/4 angle (hard to get the camera any closer). You can see the original shock hole where the stud attached to the frame about 2" below the top of the shock.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-01-2005, 06:16 AM   #14
laynlow77
thank you very very much!!! ill let you know when i get this done.
completely unrelated but you seem to be knowledgeable......i have a 77 and i want to put power windows in it...whats the easiest/best way to do it...
Old 09-01-2005, 08:46 AM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
If you want "bolt in" power windows you need to find a donor truck and rob the motor/regulator assembly along with the door harness, and the sub harness that goes from the door jamb to the main harness. Installing anything in your doors is no picnic, but that should be the easiest way to do it.
There is one company that I know of that offers a kit that is specific for our trucks. It's offered by A1 Electric Automotive Accessories and can be found here-Look inside
You can also do a generic kit like the one installed in my 77. Roger at Stoked Out Specialties has had good experience with the kits from Specialty Power Windows so that is what we used. Since I wanted a factory look, he installed thier kit along with the factory power window and locks switches.
Here is an old post I saved on the subject that has some good info-Look inside
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-01-2005, 08:49 AM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
If you do get your parts from a donor truck you will need the door panel trim too. The old door panel will have the cut outs already, but the trim will need to be modified or replaced.
Here is what the door panel looks like under the trim....
Old 09-01-2005, 01:20 PM   #17
SCOTI
SCOTI's Avatar
Yep, what he said. A-1 or Specialty Pwr. Windows w/the nod toward A-1 as the easier of the 2 when retro-fitting.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-03-2005, 02:11 PM   #18
woodyjim
Hey, N2TRUX!
I'm glad this came up. My '84 has factory power windows but it seems like they just [I]barely make it to the top. Is this just the older technology or do I need to replace something? Thanks for any help!
woodyjim is offline   Reply With Quote
