Old 09-09-2005, 08:31 PM   #1
David Johnson
David Johnson's Avatar
Drug the junkers home today
Here are the pics I promised. They aren't much to look at, but they were CHEAP. I still have one to get. What do you think?
David Johnson is offline   Reply With Quote
Old 09-09-2005, 08:33 PM   #2
David Johnson
more...
Old 09-09-2005, 08:37 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Well the rollbar isn't original, but man what a steal, you are so lucky, JMHO
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-09-2005, 08:43 PM   #4
71jimmy
71jimmy's Avatar
Are you going to part anything out? If so, I would be interested in a set of original seats and the front and rear carpet strips. Send me an email when you make a decision. Thanks
By the way, you gotta save the JIMMY
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 09-09-2005, 08:50 PM   #5
Big Block
Big Block
Big Block's Avatar
Looks like you have a pretty good starting point to build a nice blazer. B.B.
Big Block is offline   Reply With Quote
Old 09-09-2005, 08:54 PM   #6
David Johnson
There are actually two roll bars, which one is not original? Or are they both aftermarket.....Oh, I just noticed that the second is not pictured. I'll try to get one.
Old 09-09-2005, 08:55 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I only see one in that one pic, where is the other, or am I just blind, lol
Old 09-09-2005, 09:11 PM   #8
David Johnson
Here's the other one.
Old 09-09-2005, 10:28 PM   #9
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Nice score! They don't look like they are in that bad of shape from the pictures.
I don't think either of the roll bars are original. The first one pictured looks like a smittybilt. The second looks like it is either home made or a modified pickup roll bar. Does it go through the floor?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-09-2005, 10:40 PM   #10
David Johnson
I didn't look close enough and now it's dark. I'll check later. As you can tell, I don't know ANYTHING about blazers/jimmys. I usually build trucks and musclecars, but I've always wanted one of these blazers.
Old 09-09-2005, 10:56 PM   #11
71RestoRod
71RestoRod's Avatar
I probably missed something... but if you are at all interested in selling that Smittybilt rollbar I would sure like to get in line!
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 09-09-2005, 11:42 PM   #12
bouncytruck
SKINNY TIRES RULE!
If the one in the first picture has the rear "legs" of the roll bar bolted to the main hoop, it is most likely a smittybilt roll bar. On the "original" roll bars, the rear legs bolted to the front of the wheel tubs.
I'd bet between all of them, you could probably build a nice rig, and have a lot of left over parts to help "fund" the build.
bouncytruck 1972 K5
Old 09-09-2005, 11:50 PM   #13
David Johnson
That's the plan. I really want a 2wd though, but I will build a 4wd since the chances of finding a 2wd frame might be a little slim. The 4th blazer that I haven't brought home yet is a 2wd, but it has been hit really hard and the frame is probably toast. The only reason I'm getting it is the chance the frame MIGHT be okay. It has no suspension and has been setting on the ground for years. It will be a real PITA to get it home.
Old 09-10-2005, 09:12 AM   #14
Yukon Jack
Yukon Jack's Avatar
Other than missing some parts, none of the ones pictured look too bad. A great find for sure.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-10-2005, 12:23 PM   #15
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
If you would like to sell on of the bodies let me know..... Driving down there wouldn't be all that bad Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 09-10-2005, 01:39 PM   #16
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks like some really nice blazers you have found.....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-10-2005, 03:03 PM   #17
David Johnson
71blksuper4X4 - I will sell one of the bodies, but it has some wreck damage. I don't know if you would want it or not. From the doors back it good.
Old 09-10-2005, 05:08 PM   #18
bisquik65
bisquik65's Avatar
I would not scrap the 2wd frame,they are hard to find and if all the damage is in front of the firewall,a front of a 2wd pickup frame can be put back on it and fixed right up...
bisquik65 is offline   Reply With Quote
Old 09-10-2005, 06:26 PM   #19
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Damn, sweet find there. None of them look all that bad at all to me. They will combine to make 1 or a couple of sweet Blazers.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 09-10-2005, 09:28 PM   #20
jamie72
jamie72's Avatar
looks like a great start on a nice ride!! the bodies look pretty good.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 09-10-2005, 10:14 PM   #21
72 Cheyenne K20
Hey David, congrats again on your find. Looks like you have all the pieces to make what ever you want. Wanted to ask if you were going to sell the roll bar from the red topless blazer or if Donkey69 already laid claim to it. Let me know when you get a chance.
Thanks, Scott
72 Cheyenne K20 is offline   Reply With Quote
Old 09-10-2005, 10:30 PM   #22
Swbman
David, from what I see you made a Great Score, Congradulations......
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay
Swbman is offline   Reply With Quote
Old 09-10-2005, 11:23 PM   #23
David Johnson
Thanks you guys, I feel better now about dragging them home. I was feeling like maybe I made a mistake about the time I was changing the fifth or sixth wheel and tire, lol.
Old 09-11-2005, 11:00 AM   #24
mtnbutch
very nice find! Someone's loss, your gain........Good Luck with your project.
mtnbutch is offline   Reply With Quote
Old 09-11-2005, 12:45 PM   #25
bouncytruck
SKINNY TIRES RULE!
here's a 2wd rig that might work for a solid frame. Might as well add one to your collection...
http://adcache.collectorcartraderonl...6/80829426.htm
bouncytruck 1972 K5
