Old 09-12-2005, 12:34 PM   #1
72 longhorn BB
72 longhorn BB's Avatar
Big block parts identification - can you solve this?
Hey there my big block bretheren,
It has been three years since I took it apart and now she is going back together and back into the longhorn.
Only problem is, it has been a while and I can not remenber what these parts are for.
Can you tell me what they are?
Also, I am trying to find a replacement exhaust manifolt blot/stud for teh left front hole that the PS bracket attaches to.
anyone got one, or know where I can find one?
Much thanks in advance me amigos!
-Chuckster
Chuck
1972 C-20 Longhorn
402 BB .030" over (409?), curved HEI,
RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit
1999 K1500 Suburban (old style)
5.7L Vortec
4L60E
"No matter where you go, ........ there you are"
72 longhorn BB is offline   Reply With Quote
Old 09-12-2005, 12:38 PM   #2
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
the long one in the top pic looks like the vacuum for the trans.......if you have auto
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 09-12-2005, 12:39 PM   #3
panhandler62
Java Mechanic
panhandler62's Avatar
In the first picture you have two vacume fittings.. the small one looks like the signal line for the distributer and the second like it might be for a PCV fitting.
I'm not sure what the gizmo in the second pic is.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-12-2005, 01:13 PM   #4
72 longhorn BB
Ok, so
C = Trans vaccum line
B = PCV?
A = ?????
What about the manifold stud/bolt?
Anyone know where they can be gotten?
Chuck
1972 C-20 Longhorn
5.7L Vortec
4L60E
Old 09-12-2005, 01:23 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
A=Vacuum advance from carb to dizzy
B=Crankcase ventilation but not the PVC valve. Goes to fire arrestor spacer that sits on top of carb to RH valve cover
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-12-2005, 01:52 PM   #6
Frizzle Fry
Frizzle Fry's Avatar
I just installed headers and I used a long bolt with two nuts on it where you are describing. One nut to tighten the header flange, and the other to sandwich the PS pump bracket with the bolt head.
Edit: The manifold had the same bolt with a spacer instead of the nuts.
Frizzle Fry is offline   Reply With Quote
Old 09-12-2005, 02:01 PM   #7
panhandler62
Java Mechanic
That's correct. I was wrong.
Keith
Old 09-12-2005, 03:02 PM   #8
72 longhorn BB
Thanks all for the parts ID info, and the suggestion for the PS bracket stud.
I am really trying to make it look OEM, though, so I am trying to locate a bolt/stud that looks like the one in the illustrated parts book.
tThis is a crude drawing, but it shows what I am talking about.
It must have gotten lost when it was being rebuilt.
Gotta find a replacement.
Any ideas men?
Chuck
1972 C-20 Longhorn
5.7L Vortec
4L60E
Old 09-12-2005, 05:07 PM   #9
acloco
B is the fresh air side of the PCV valve - breather in factory air filter housing.
Spark arrestor type is longer and has one more bend in it....had to go under the air cleaner.
The stud you are looking for...harder than heck to find....try GM parts.
acloco is offline   Reply With Quote
Old 09-12-2005, 07:08 PM   #10
kelsfine69
18 Till I Die
kelsfine69's Avatar
I also had a hard time finding that stud/bolt. Go to a big truck wrecker, 3 ton , schoolbus....etc.........I found a lot on a bus with a 427BB
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 09-12-2005, 07:47 PM   #11
demi
demi's Avatar
You Could try here - ClassicIndustries.com
Part #1256624
demi is offline   Reply With Quote
Old 09-12-2005, 10:42 PM   #12
72 longhorn BB
Dude, thanks
Hey guys, do any of you have any pictures of all the hose routings on your BB's?
I don't know why I did not ask about this sooner, but it makes sense.
My rig is trying to be totally OEM, so if you have any pictures of teh hoese and tubes we just described while in their installed locations, it would be VERY VERY appreciated
Thanks ahead of time!
-Chuckster
Chuck
1972 C-20 Longhorn
5.7L Vortec
4L60E
