Old 09-12-2005, 01:07 PM   #1
skillet
skillet's Avatar
One-piece oil pan gasket
Has anyone tried the one-piece silicon rubber oil pan gasket from Fel-Pro? I saw one in Chevy High Performance Jan. '04. And do you need to raise the engine(350) to install the oil pan gasket? Thanks for any info.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter
skillet is offline   Reply With Quote
Old 09-12-2005, 01:29 PM   #2
cableguy0
lots of folks here have used em with very good luck. in a 2wd truck its a ton easier if you lift the engine out. the pan bolts are near impossible to get out and back in with the engine sitting on the mounts.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-12-2005, 01:30 PM   #3
cdowns
cdowns's Avatar
a great product!! yes you need to unbolt the engine towers and lift the engine enough to get a short piece of 2X4 under the towers to change the gasket
Old 09-12-2005, 02:27 PM   #4
skillet
skillet's Avatar
This is probably a dumb question, but are the towers the spots where the engine sits on the motor mounts? Thanks again.
Old 09-12-2005, 02:29 PM   #5
cableguy0
yup they sure are. just take the one bolt that holds the mount to the towers out and raise the engine
Old 09-12-2005, 02:33 PM   #6
skillet
skillet's Avatar
Can you just jack up the engine to raise it or do you have to use a hoist? I am in an apartment complex. Thanks again very much.
Old 09-12-2005, 02:33 PM   #7
Jakes-66-K10
Jakes-66-K10's Avatar
I swear by these gaskets! They are amazing! Never had to replace the one in my '70, but in my '66 I was able upgrade to the one piece without lifting the engine.
Jakes-66-K10 is offline   Reply With Quote
Old 09-12-2005, 02:39 PM   #8
cableguy0
the safest way is to use an engine crane. living in an apartment complex myself im aware of your dillemma.you could jack the engine up using a block of wood on the pan just be careful that you dont crush or dent the pan and make sure you support it will dont need that thing falling and crushing your hands
Old 09-12-2005, 04:15 PM   #9
matthufham
the one piece gaskets are definately better than the 4 part, or 2 part with a bottle of sillicone gaskets. dab some sillicone on the gasket to hold it in place.
matthufham is offline   Reply With Quote
Old 09-12-2005, 04:31 PM   #10
Russell
Professional Grade
Russell's Avatar
I put one on my GMC, and not a drip since. Definitely worth the time and effort!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-12-2005, 05:50 PM   #11
hilljob26
hilljob26's Avatar
they work great except fpr the fact that you cant use them on an aluminum oil pan,i tried with mine,and the front seal is too thick to let it suck down tight,i ended up braking the front of my pan and had to reweld it at work
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 09-12-2005, 05:58 PM   #12
70c10swb
no brain no headache
70c10swb's Avatar
can they be re-used. i had one (or i should say have) on my SBC never ran it but it (the pan) was tightened down then i removed the pan. So will i be alright?
1996 GMC Sierra z71
1970 SWB 2wd (project)
70c10swb is offline   Reply With Quote
Old 09-12-2005, 06:12 PM   #13
Stroker
The the new gaskets are a huge improvement over the old design. I think your best bet would be to rent or borrow a hoist to make the swap. The block and jack on the bottom of the pan works okay for engine mounts and header installs but it's going to be tricky for a pan gasket change.
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 09-12-2005, 06:13 PM   #14
70GMCer
70GMCer's Avatar
anyone have the Fel-Pro number for this gasket?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 09-13-2005, 02:48 AM   #15
4x4Poet
Other than one piece oil pan gaskets, I'm not sure which type gasket you're refering to. I only have the part # for the PermaDryPlus oil pan set:
OS 34509 T Oil Pan Set
GM Prod. V8
...265,283,302,327,350,400 Eng., 1957-74
Gasket Set Includes:
1- 34509 T Oil Pan Gasket
4- 95560 Oil Pan SnapUps
14- 95685 Oil Pan Bolts
14- 95686 Star Washers
4- 95687 Oil Pan Bolts
4- 95688 Start Washers
PermaDryPlus gaskets all come with instructions that say to NOT use any sealant which would ruin the gasket's sealing abilities. (I like that part )
I'm not sure if Felpro offers just a PermaDryPlus oil pan gasket without bolts at a lower cost.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 09-13-2005, 09:22 AM   #16
skillet
skillet's Avatar
That's the gasket they talked about in the magazine, 0S 34509T.
