Old 09-14-2005, 10:44 PM   #1
KEH
Better late than never
KEH's Avatar
Aluminum pulley squeal
I have replaced the water pump pulley now a couple of times because of belt squealing when running the a/c. I have replaced the belts, which temporarily solves the problem, but the squealing returns after a few days.
I have tried different belt manufacturers, but they all do it. I have also tried belt dressing to no avail. It is only when running the a/c.
Does anyone else have this problem too. Is the only cure a steel pulley?
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 09-14-2005, 11:06 PM   #2
acloco
Your compressor is low on freon or you have a bearing going out on your compressor....or...your A/C is freezing up and making the pump work too hard.
acloco is offline   Reply With Quote
Old 09-14-2005, 11:16 PM   #3
kelsfine69
18 Till I Die
kelsfine69's Avatar
Try cleaning the pulleys/belt with a brake clean . Lightly sand the aluminum pulley with scotch brite or fine sand paper. I had a alt belt squealing problem and alum waterpump pulley and I had to really tighten the belt to get it to stop. Another old trick is put a little copper coat on the belt as a dressing, it has a grit in it that helps. M2C
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 09-15-2005, 09:08 AM   #4
Blue4x4
Blue4x4's Avatar
how is the alignment on the belts? Sometimes by going with a different pulley it off-sets the Alignment.
Blue4x4 is offline   Reply With Quote
