Old 09-15-2005, 10:23 PM   #1
gregbr
Senoir Member
gregbr's Avatar
Help: Need to ID this engine
We were told its a 68 350. You know how that goes. This is what I can find so far:
On rear near ditributor 3970010 and 588 (I think its a 5).
On both sides of block 010.
On front pad VO712CHC & 18N683036 (I think, they are stamped together).
If I need to supply more info, tell me where to look. THANKS. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 09-15-2005, 11:05 PM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
CHC comes back as either
1973 CHC 307 tur hydro, Calif NB2 115 2 F B X
1975 CHC 350 m/t, h/p T L82 205 4 Vette
1976 CHC 350 m/t, h/p X L82 210 4 Vette
1980 CHC 350 auto trans. L - - full size
18N683036 would probably be a partial VIN...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 09-15-2005, 11:06 PM   #3
72 CustomCamper
huh ???
010 is a high nickel block. Good for a race motor...
Chuck
Old 09-15-2005, 11:15 PM   #4
justascatch
Justascratch
Engine ID
3970010 = 1969 thru 1980
No such thing as 1968 350
Front pad ID is specific to the application i.e. (was in a car, truck so on)
e-mail tmgrawlookalike@hotmail.com and he will reference the front pad #'s.
To read the date code...stand at the back of the eng, with the 3970010 on your left, the date is just to the right of the distributor on one of those little ledges. Should be a letter and 2 or 3 #'s ( A 5 2 is Jan 05, 1972) ( B 10 3 is Feb 10 1973) and etc. The letter corresponds to a month, the 1st #(or 2 #'s) is the day, and last is year.
Go to mortec.com for casting # info.
Hope this helps.
Scratch
justascratch-OKC,OK
justascatch is offline   Reply With Quote
Old 09-15-2005, 11:17 PM   #5
justascatch
Justascratch
3970010
Forgot to say 3970010 is 350, can't be 307 or 283 or 327
justascratch-OKC,OK
Old 09-15-2005, 11:18 PM   #6
Randy70C-10
Randy70C-10's Avatar
Those came in two and four bolt mains, strong casting either way!
Randy70C-10 is offline   Reply With Quote
Old 09-16-2005, 12:13 AM   #7
gregbr
Senoir Member
gregbr's Avatar
The engine is in a truck, so some parts are hard to see. But, while looking at it from the back, with 3970010 on my left, the date code is on the right....can't make out the letter, ?88. Anything else to look at? Greg
Old 09-16-2005, 12:23 AM   #8
masterbeavis
Having issues
masterbeavis's Avatar
are you trying to identify what it came out of, or displacement? Was it one of those deals where you bought it cuz it was a camereo motor, thus having 500HP factory, after you add chrome valve covers??
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 09-16-2005, 12:29 AM   #9
gregbr
Senoir Member
gregbr's Avatar
Just trying to figure out the HP and what it came from. The nastyz28.com page, it shows the 3970010 as a 68 327 & 69-80 350 and also lists the CHC as a 350 in a 78 Camaro. On Mor-tek it list 69-80 350, 69 302, 69 327. So it looks like a 78 350, Right? Greg
Old 09-16-2005, 12:46 AM   #10
masterbeavis
Having issues
as previously stated, that casting number was used for along time. My guess is that the previous owner got confused and said '78 instead of '68. Thats the one thing I dont like about buying used motors. The seller tells ya one thing, you get it home and find out another. I bought a 350 that supposedly was running. Its only issue was it had compression higher in one cylinder than the others. No big deal I was assured by seller. I happened to know the guy he got it from, he said it had a WATER LEAK, and thats why it had higher compression. So much for a turn key motor.
Old 09-16-2005, 07:15 AM   #11
wink05
Very confusing...various resource materials.....different answers
My $.02 from research:
The 8 in the 18N683036 indicates year 1968 or 1978
However no engines were made in 1968 or 1978 as CHC (taken from the V 07 12 CHC number)
A couple of things: 1) double check the numbers you've given, 2) try to determine the engine date with mirror and light,
3) if dipstick is located on drivers side it's pre 1978, passenger side it's post 1978
FYI there was a 3970010 in 1968 as a 327, (still doesn't explain the CHC though).
wink05 is offline   Reply With Quote
Old 09-16-2005, 07:43 AM   #12
mrein3
mrein3's Avatar
I've owned two 350's with 3970010 cast in the back.
One was a 2 bolt main 350 that came out of a 1971 Monte Carlo. Now it is a 383.
The other was in my truck when I got it. When I took the pan off the bottom it had 4 bolt main caps.
So I guess what I'm trying to say is that it is probably a 350. It could have either 2 or 4 bolt main caps.
Most car suffixes are Cxx stamped in the front (yours is CHC) the Monte (2 bolt) was Csomethingsomething. The engine that was in my truck (4 bolt) has a TXD suffix which decodes to something like a 1976 or 78 truck.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-16-2005, 09:52 AM   #13
justascatch
Justascratch
so you don't have the month, but you do have the day (8) and the year (78). No front pad # corresponds to '68. I would bet $ it is a 1978 350 2 bolt main eng. '78 (date code), car (front pad). Let us know how it turns out.
justascratch-OKC,OK
Old 09-16-2005, 12:23 PM   #14
dons454s
dons454s's Avatar
With all the info you have combined my books say its a
78 camaro 350 cid 170 hp auto tranny lm-1 rpo 1-4 brl carb
dons454s is offline   Reply With Quote
Old 09-16-2005, 12:47 PM   #15
gregbr
Senoir Member
gregbr's Avatar
I have pics....should have done this first, they show more detail. I found a CHC listed in the 78 Camaros on nastyz28.com, it was not listed under the casting numbers as a 78 anything. Oh, the oil dipstick is on the drivers side.
Old 09-16-2005, 05:03 PM   #16
Blazer1970
Blazer1970's Avatar
G88 casting date code is July 8, 1978. V0712 says the engine was assembled on July 12th in Flint. That makes sense.
Blazer1970 is offline   Reply With Quote
Old 09-16-2005, 07:27 PM   #17
acloco
ALL 010 blocks are 4 inch bores.
There were several 1968 350's - in fact, the only small block you could get in a 1968 Camaro SS.
acloco is offline   Reply With Quote
Old 09-16-2005, 11:10 PM   #18
justascatch
Justascratch
Confusion
With all due respect to ACLOCO, no 350 in 1968 was 3970010 casting. I am done, I think we have beaten this horse enough...
justascratch-OKC,OK
Old 09-16-2005, 11:54 PM   #19
gregbr
Senoir Member
gregbr's Avatar
Thanks to all!! Greg
Old 09-17-2005, 01:16 AM   #20
acloco
Actually...there is....and there is some casting #'s not on the normal casting number websites. Of note, I have (currently being used as well), a 1968 4 bolt, 3980010 block - it IS out of a Massey Ferguson combine - yes...an industrial 327! 4 bolt block, LT1/Z28 rods, forged/large journal crank.
Also...just because the casting number sites say 1969 & up.....if you have an early production 1969 vehicle...you have a 1968 block. Here is your info from mortec's website........
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
