09-16-2005, 08:28 AM | #26 |
The right lense may be as important as the right welder
First, I am lousy at welding, so this is not expert advice. Second, I recently switched out the lense in my helmet from an 11 to an 8. In one day, my welding improved 100%. I can finally see what I am doing. I am not suggesting that everyone should use an 8. However, I wear glasses. This automatically cuts down on the available light. I never new I had a choice of lenses. So if you find that you cannot see what you are doing, just remember that you are not locked into one grade of darkening lense. I think the new lense cost me less than $3.00. I screwed up way more steel than that over the years so it is worth expirementing. You don't have to make such a dramitic jump from 11 to 8, considering the cost of the lenses and the value of your eyes you may want to sneak up on the right grade for you.
09-22-2005, 11:14 PM | #27 |
registered IWATA user
i'm pretty sure 10 is the lowest you can go for mig welding, its just your eyesight though you might want to check into that
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black -'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end. -01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny. Take off that Von Dutch hat before i stab you with a 000 Mack. |
09-23-2005, 05:19 PM | #28 |
Project 2 Resume
I've been using "9" for many years without any problems. I don't wear glasses at all.
John 1984 C30 Chevy Crew Cab Dually 1998 Jeep Cherokee 4x4 2004 Chevy Trailblazer 4x4 (wife's) 1970 Mustang FB fully tubed (getting 521 BBF & powerglide) 1978 Nova 2dr (going BBCaddy & S.P. th400) 1984 Monte SS (circle track car) |
09-25-2005, 08:46 PM | #29 |
Junior Member
We have an L-tec at our shop. We got it from the local parts store about 17 years ago. We have abused it continuosly and it has worked great. We repair garbage containers, truck frames, and do some fabrication with it. I even welded a fender bracket on my son's Blaster today, no problems. I would like to find a good 120v welder for using at the house to save trips into the shop.
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
09-27-2005, 01:27 PM | #30 |
Questionable
Hey guys,
I think I'm going to take the plunge and buy a welder. I guess it's the last thing that my shop is missing, honestly (except a plasma cutter, metal brake, drill press, DA sander, ... ). Seriously though, I know nothing about welding. I don't know what people mean when they say "ARC" welder, I don't know what TIG and MIG means, when you would use gas mixtures, what gas mixtures have what benefits, what kinds of wire to use with different welders.... Man, I need some help learning all of the ins and outs of welding and the styles and uses. I'd also like to find a welding tutorial online for welding different types of steel together - it would be nice to have a matrix (grid) showing what type of welding works best in diff't situations. The types of welding I can see myself doing consists of: Welding fabricated brackets together, welding things to my frame, shaving body panels, doing other body work like frenching an antenna housing into my stock gas filler hole. I see lots of welder recommendations above, but that doesn't help if I don't know if that welder is right for what I want to do. I don't even know how you'd add gas to a system or what that means I'm a super-n00b. If anyone can give any advice or answer any questions I have above, please help. Thanks
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
09-27-2005, 10:14 PM | #31 |
hey shifty go to your local miller store and ask some questions. if the welder is a MIG it is gas ready. there is a hole in the back, plug in the hose, read the directions/watch the included video about reversing the polarity and stuff, then start welding. if you want to do body work its not even worth practicing with fluxcore. you'll only learn by digging into an old fender and warping some panels. check out www.millerwelds.com to see the choices. the chart with the diff setting/thickness stuff can be found on the inside of your welder. its not as hard as it sounds.
09-28-2005, 07:21 AM | #32 | |
mig welders are the best choice for an all round welder,some thing around the 150 amp-200 amp range should do all the work that you will be doing. |
09-28-2005, 08:22 AM | #33 |
learning to weld is a mostly hands on deal//most welders come with a good instructional video and book//
places for help: 1 local welding supply /lincoln and miller both have schools and sumtmimes have travilin techs that have seminars//and the local sales guys will be glad to take thier time to get you started on the basics and have info on local training// while on this subgect i'll also add that sometimes it's worth the premium price of dealin local to get this knowledge and tech support in the future 2 local community colleges or trade schools for a 5-6night course 3 local library ====nothing like a good book// places like speedway,summit,jegs have good books on welding//eastwood has expensive videos its really not as hard as brain surgury just start picking up old pieces of metal off the side of the road for practice an go at it i have a nice 220volt/135amp lioncoln welder for sale $350 if you want to pickup in daytona i'll give u some quickey lessons
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 05-12-2006 at 08:06 AM. |
09-28-2005, 09:30 AM | #34 |
Questionable
Thanks guys.
cdowns - I think I might buy locally just for the sake of ease as everyone seems to be mentioning. there is a new Hobart Handler 135 someone has for sale here for $300, but after reading krue's first post in this thread, I'm thinking it won't do argon/c02 mix. It would be perfect though - I've got two weddings near you in the next 3 weeks .. one in Fernandina Beach, one in St Augustine.
09-28-2005, 11:27 AM | #35 |
that quick lesson from krue might be worth not buying locally. videos are cheap and the welding place still will help you if you buy your bottle/gas/gloves/mask/etc from them
09-28-2005, 12:20 PM | #36 |
Questionable
what quick lesson? i think i missed something. i was just thinking about buying a welder locally. i've got a friend with a bunch of welding DVD's ripped to his computer (gotta love technology), I'm downloading those off of him right now so i can actually have a chance of educating myself at home before venturing out in the world.
09-28-2005, 06:27 PM | #37 |
Questionable
Here is a link to LOTS of educational material on welding from Miller:
http://www.millerwelds.com/education...pamphlets.html Lots of cool projects for beginners, novice and advanced here: http://www.lincolnelectric.com/community/projects/ Just look for the links that start with "Project:"
09-29-2005, 12:50 AM | #38 |
Hollister Road Co.
For beginners just one note about galvanized metal welding if you weld it and the fumes go into your helmet and you think hey that stuff doesn't smell to bad, kinda sweet smelling. You may think your going to die the next day you may have the shakes and the feeling that if someone killed you now it would make it better. Drink a glass of milk it helps. Then use a fan to exhaust the fumes to somewhere else.
10-01-2005, 01:30 PM | #39 | |
'Burban Legend
Any Other L-tec Users?
'67 Chevy Iron City Beer Truck (9ft step) '67 Chevy Panel Truck 467 '68 Short Fleet 305v6 '68 McLaren Ramp Truck '68/'68/'70/'71 Burbs 292/366/402/454 '69 C-30 dump '71 C-50 dump and church bus '71 4x4 454 '72 Blazer (w/pop-up camper) $15 x-hooks '66 Chevy II 194/Weber '68 El Camino" 305v6 '69 Skylark 455 Buick '70 Chevelle 427 '71 Cutlass W-31 '71 GTO 400 2x2 "The 51" Chopped '51 Chevy (409) my first car OK Toad, we'll take 'em all... John Milner |
10-22-2005, 11:04 PM | #40 |
Junior Member
Re: Welders!
Well.... now that I bragged about how good our L-tec was it blew up today. But it gave me an excuse to go buy myself a new one. I bought a Hobart 140 at the local hardware store. $475.00, cheaper than any of the internet sights had it listed for. I used it to fab up a platform out of square tubing, and it worked great. The only bad thing was I had to leave it at work until we get the old one fixed.
11-08-2005, 11:31 PM | #41 | |
Re: Welders!
TIG is actually one of the hotter processes, but you have such great arc control that you can regulate the heat very well. Short Circuit MIG is the coldest process, and prefered for sheetmetal work. |
11-09-2005, 10:58 PM | #42 |
Re: Welders!
I use the Millermatic 110 volt wirefeed alot....
Also have a Lincoln Stick welder, and a Miller plasma cutter
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
11-09-2005, 11:06 PM | #43 |
Project92 SWB stepside
Re: Welders!
I have a hobart ironman 210 unit. Ive had it for a few yrs and love it. Kinda a big non portable machine but very handy!! ran around $1400
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
12-06-2005, 05:55 PM | #44 |
Still Green but learning
Re: Welders!
OK so I have a question, If I am buying one of these to do my rockers and fill some holes from old tonneau covers, NO FRAME work what is the thickness of that metal? what guage? that way when shopping I know if it can do most of what I want....
I will also use it on my imaginary 67 camaro conv. one day too :-)
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
12-09-2005, 08:17 PM | #45 |
Re: Welders!
OK Guys
I just bought a snap-on YA-240 wire feed 240 amp DC 80% duty cycle takes 33 lb spool of wire up to .045 wire has stitch mode and argon/c02 tank flow rate regulator new gun about 2 months old for $500.00 I think I did good. what do you guys think? EMMETT
Kaukauna WI Airplaines don't land here they are sucked down |
12-24-2005, 08:02 PM | #46 |
Re: Welders!
I have a miller 251 It is a sweet MIG welder tthat is well worth the money. you can weld sheet metal and up to 1/2 inch steel..
12-25-2005, 10:11 PM | #47 |
Questionable
Re: Welders!
I'm having a tough choice. I was lookin at the Lincoln SP-175 Plus and the Millermatic DVI. The DVI variable input voltage setup is appealing - don't feel like rewiring for 220 in the garage. I have been dorking around looking at the Hobart 175 as well.
Just curious - what is suggested for fram welding/auto body work - tap feed or continuous feed? Does it matter? Maybe those two welders are overkill....
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 12-25-2005 at 10:33 PM. |
12-26-2005, 12:22 AM | #48 |
Re: Welders!
Shifty
I had a friends LINCOLIN 135 worked an 115 volts. It did all the welding I was doing. For frame work you want continuse welding if your new at welding try to find someone experienced with these frames I only stretched semi frames which had to be plated in and out. As far as panel welding I always tack or spot weld then stitch about 1-2 inches at a time eliminates a lot of worpage. The snap-on I have now is a little bigger than I need but I think the price was right. Good Luck finding one EMMETT
01-04-2006, 03:32 PM | #49 |
Questionable
Re: Welders!
I installed a new double pole breaker and 220 outlet in the garage this past weekend, so working @ 115 is not a problem anymore. I'm now looking at the Lincoln or Millermatic 175 now. Torn on which to get, trying to find one used. I want something that will do framework in one pass, wire feed, ability to do stitch and ???
It's such a big investment. It's gonna take me forever. I've just started hearing about the Snap-On welders. Can anyone elaborate more on that product? Everyone has been pushing me to get a Lincoln or Miller. I know they're well known brands, but I'm a little ignorant and I know others have much more experience.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 01-04-2006 at 03:34 PM. |
02-11-2006, 07:28 PM | #50 |
Re: Welders!
Hay guys I know this welder has been asked about but the harbor friaght hear is having a 2 day sale and I can get it for $89 would it be good for welding in rockers and floor boards. Mainly patch pannel work. http://www.harborfreight.com/cpi/cta...emnumber=44567
Earl 68 2500 4x4 GMC Burb |
