09-18-2005, 11:51 AM | #1 |
66C10 Power Steering
What later model power sterring gear will bolt up to a 66 column shaft? Or how did you complete this task?
thanks |
09-18-2005, 08:29 PM | #2 |
none will bolt up. you can use the "rez"conversion kit to use a 71-87 power steering box.it requires minor welding.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
09-19-2005, 01:03 AM | #3 |
YES_____NO
Brothers sells a kit that requires no welding, just have to drill one extra hold in the frame
Power sterrung Adapter kit
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board |
09-19-2005, 08:42 AM | #4 |
I believe the welding zenish was reffering to is when you cut the steering column rod....due to the power steering box being longer than the manual box...
09-19-2005, 10:00 AM | #5 |
I believe that Brothers kit and the Rez Engineering are the same thing. Check out www.americanclassic.com, I remember seeing they have pre-made column shafts the right length, so you don't have to cut up yours if you aren't experienced at welding.
09-19-2005, 02:11 PM | #6 |
or u can swap steering columns i got a 91 sub column in mine no welding.
65 c10 tore apart 70 c10 305/350th |
09-19-2005, 08:22 PM | #7 |
chevy283 --got any pics----thanks
09-19-2005, 10:42 PM | #8 |
I never welded anything. I put on the rez eng kit with a mid 85's box and used a stock intermediate shaft (the collapsible type) new rag joint. 68 tilt column
09-20-2005, 06:18 PM | #9 |
no it looks cool though. Check out this site he used a 80s sub colume. http://geocities.com/vapershing/pickup.html
65 c10 tore apart 70 c10 305/350th Last edited by chevy283; 09-20-2005 at 06:19 PM. |
