Old 09-18-2005, 07:54 PM   #1
CAL 58 GMC
CAL 58 GMC's Avatar
Brake line help
I need some help on getting the right size brake lines. I have 58 GMC that has a Camaro clip up front and a 2003 Blazer rear dif. I have TCI's 55 to 59 frame mount power boaster and a Corvette style master cylinder. Does anyone know what size lines I neet to run?
CAL 58 GMC is offline   Reply With Quote
Old 09-18-2005, 08:48 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
They should be 3/16 for disc and 1/4 for drum. The 2003 blazer may be metric so you would need a metric fitting and the equivalent size tube. If you go to http://www.fedhillusa.com/pages/709975/index.htm you can get some brake line that works very well and is much easier to flare. They also have the fittings you will need.
Old 09-19-2005, 03:32 AM   #3
CAL 58 GMC
CAL 58 GMC's Avatar
Thanks dwcsr for the info!! I really appreciate your responce! I will check that link out.
