Old 09-18-2005, 08:19 PM   #1
dmigura
1975 Blazer Questions?
I have aquired a 1975 Blazer w/a 400 short block. It runs great but the body is in very bad shape. I am thinking of parting it out Should the front axle be a Dana 44? If so can I put all the brake parts on my 1970 4x4. Including master cylinder. Also I thought it would have a 205 transfer case. But the shift pattern is 4loc, 4, N, 2, 2loc. Is this a different transfer case.
thanks for the help.
dmigura is offline   Reply With Quote
Old 09-18-2005, 08:47 PM   #2
marianne
Factory front axle is a Dana 44. It will have a gear tag attached to the bottom gear cover bolt telling you the ratio. The shift pattern you refer to is the NP 203, which was standard on all 75 Jimmy/Blazers equipped with auto transmissions. It is a chain driven unit. Full time 4 wheel drive.
Dont know if the brake parts will swap though. I know little about the earlier ones.
Curt
marianne is offline   Reply With Quote
Old 09-19-2005, 12:55 AM   #3
Mudder
Mudder's Avatar
You could swap the whole axle out pretty easy.
Mudder is offline   Reply With Quote
