Old 09-19-2005, 01:12 AM   #1
Ed ke6bnl
np203 or 205??????
I have a 1970 chevy 4x4 k-10, and i wanted to find out what transfercase i have? Also when i move the rear yoke side to side there is some slop. So i want to know if there is suposed to be some slop or no slop at all?
Thanks for all the help James
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 09-19-2005, 02:17 AM   #2
earl87gta
earl87gta's Avatar
you should have a 205 but just in case go here. they have pics of each that will help you out http://www.advanceadapters.com/catalog/040.html
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 09-19-2005, 02:49 AM   #3
Ed ke6bnl
Thanks that helps me out alot. So from what i can see, i have a np205 because i have the plate with the three holes in it. But the only other question i have is if my transfercase hase to much slop? Is there anyway of checking the slop in the transfercase? Thanks again James
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
Old 09-21-2005, 04:15 AM   #4
1972
Majician
1972's Avatar
The yoke is supposed to be tight. Be sure the big nut that holds yoke to the shaft is tight. You will need to unhook the driveshaft to get to the nut.
1972 is offline   Reply With Quote
