Old 09-19-2005, 04:27 PM   #1
sleepyboy
'69 Step
Do I need brake booster brackets
Have power brake booster painted and ready to install with one question. I see alot of guys not installing the side and lower bracket. Can I ditch them also without issues? Was chevrolet over cautious on this? Any thoughts? I'd rather NOT use them.
sleepyboy is offline   Reply With Quote
Old 09-19-2005, 04:46 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
I have wondered the exact same thing. I got all my stuff off a truck in a 'yard. I got it all installed and tried to make the brackets fit. I could not get the danged things to fit. I don't know if they drilled holes or what, but no matter how I moved them around (I even went back to the 'yard to look at another truck with power brakes) I could not get them to work. I did drill a hole to install the side bracket, but I could never even get the lower bracket to line up with the firewall. I installed a '71 booster on a '67 cab. I don't really know if you need 'em or not.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-19-2005, 05:06 PM   #3
StingRay
StingRay's Avatar
If you use yor truck alot and don't have those brackets you may crack your firewall due to the booster and MC vibrating. They were originally installed for a reason.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 09-19-2005, 05:36 PM   #4
70GMCer
70GMCer's Avatar
I just used the rod piece on mine and not the channel piece.........
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 09-19-2005, 05:42 PM   #5
John Fabris
TOTY 2006
John Fabris's Avatar
I am assuming that you are talking about the two brackets that go from the firewall to the booster/master cylinder. Isn't the booster that has the two brackets from a 3/4 ton truck? These brackets are not on a 1/2 ton truck. (At least that is what I have seen with the two 1/2 tons, one 3/4 ton, and one 1 ton trucks I have...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 09-19-2005, 06:26 PM   #6
Swbman
The 1/2 ton trucks have one bracket,and the 3/4 tons have 2 brackets, and yes I do use them on my truck,like said earlier that's a fair amount weight with the booster and master cylinder just dangling there, I would go as to say gm did their research and figured they do serve a purpose.So Im going with that..
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay
Swbman is offline   Reply With Quote
Old 09-19-2005, 08:23 PM   #7
uncle
Brackets
I think they started using them in 71. There are some differences in the length of the flat bracket. I think some 3/4 or 1 tons are longer.
uncle is offline   Reply With Quote
