Old 09-19-2005, 06:48 PM   #1
Ed ke6bnl
To much slop np205?????
I have a 205 TC in my 70 chevy 4x4, and when i move the yoke side to side there seems to some slop, but i am not shure if that is normal or not?? thanks for all the help james
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 09-21-2005, 11:09 PM   #2
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I have a high mileage '71 with a NP205 and it has a noticable amount of slop when pushing on the truck when it is in park. I don't know if this was the case when it had fewer miles?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 09-24-2005, 01:34 AM   #3
4x4Poet
Tough call over the net. IIRC, there is an acceptable amount of play measured in degrees of rotation, but I don't have my Chevy Service Manual handy. Off the cuff, I'd say anything less than 1/4" to maybe 3/8" movement of the yoke ears is probably OK. Without taking a measurement, excessive whine or clunking would probably be more telling of a need for a rebuild. And the adapter's spud shaft could be the culprit.
Gear wear is fairly rare in an NP205 that has had the oil changed often enough. Usually, the bearings wear first and allow the input/idler/output shafts to deflect excessively. Too much shaft deflection can accelerate gear teeth wear and tear since any deflection makes the gear teeth surfaces mate while out of alignment. Heavy or frequent towing can amplify the effect.
Though I have no business doing so, I recommend gearheads try rebuilding NP205s themselves. I've found the bearing and seal master rebuild kits for $125 at a bearing sales. A dial indicator is technically needed, but lots of wheelers do without.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 09-24-2005, 11:24 AM   #4
wolfthing2000
The coupler from tranny to transfer is a big contributor to what you have.
wolfthing2000 is offline   Reply With Quote
