Old 09-23-2005, 10:12 AM   #1
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
need help truck still wont start
yesterday morning my truck wouldn't start so i replaced the cap and rotor because they looked pretty bad and then it fired right up. this morning i went to start it and it tried to fire once and that was it. what is wrong with it?
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 09-23-2005, 11:25 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
check for sparkplug firing and if none then check for 12 volts at the Bat terminal on the distributor if you have a voltmeter. You can run a hot wire from the battery positive terminal to the Bat terminal on the distributor and turn the key and try to start the engine. You may have a bad feed wire to the distributor. Since you have changed the cap and rotor and it fired up I'd say it's in the ignition system not fuel or compression.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-23-2005, 11:40 AM   #3
cdowns
cdowns's Avatar
well i've you've got points i'd say it would be a good time to set the dwell these type distributors need regular maintenance to run properly//set gap on plugs too
Old 09-24-2005, 08:27 AM   #4
Alan Potter
I've had more than one set of new points that wouldn't fire an engine. Just a thought that shouldn't be overlooked IMO.
'12 Silverado Crew Cab 4x4
'05 Silverado SWB
'67 Chevrolet CST 2wd
'49 Willys Jeepster
Alan Potter is offline   Reply With Quote
Old 09-24-2005, 09:39 AM   #5
krue
Designated A-hole!
krue's Avatar
The module in the HEI distributor can go bad. Most auto parts stores can test them for you. If you do need a new one, make them test it before you leave with it.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
