Old 09-24-2005, 04:35 PM   #1
rauto13
saving one more
rauto13's Avatar
motor mount stool question
I am not sure what to call them, but I am wondering which are the correct motor mount brackets (stools) for my 72 Cheyenne, 350 engone, ps, pb, & air. Obviously this is the metal mount that bolts to the frame & front crossmemeber and that the engine bolts to. I think the mounts in my truck are for a 1973 and later truck. I have been told that there was only one set of mounts, pictured in the garage, and I have also been told there are two different mounts, the ones in my truck and the ones in the garage.
Are there two sets of motor mount brackets or only one?
I believe the mounts shown in the photo in the garage being painted are the correct factory mounts, am I correct?
Thanks for the help.
72 Chevy longbed - now for parts
69 Chevy short fleet - needing some love
70 RS Camaro - needing more love
driver - 96 GMC X-cab
rauto13 is offline   Reply With Quote
Old 09-24-2005, 04:39 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The clean pretty ones are proper for a small block as long as they align with all three of the forward set of holes. They look very similar to inline 6 cylinder mounts, so you have to make sure they align with the forward set of holes and not the rearward set of holes like the 6 cylinder ones will.
The ones installed in the picture look like factory 72 big block mounts. Very desirable to big block guys.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 09-24-2005, 04:51 PM   #3
rauto13
saving one more
rauto13's Avatar
This maybe a dumb question, but can a small block be mounted on big block stools?
Old 09-24-2005, 05:48 PM   #4
Tx Firefighter
Sure it can.
Old 09-24-2005, 06:45 PM   #5
4x4Poet
Only F@rd motors excrete stool.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 09-25-2005, 05:59 AM   #6
gregbr
Senoir Member
gregbr's Avatar
Are the 72 small block stands like the 67-71 SB stands?
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 09-25-2005, 07:39 AM   #7
Tx Firefighter
No, the 67-71 big block stands have a sag in them to allow exhaust manifold clearance that the small block ones don't.
If you go to the FAQ section, I wrote an article detailing this with good pictures to illustrate. The article is called "big block motor mounts on the cheap" or something like that.
Old 09-25-2005, 08:59 PM   #8
Bob Moore
Actually I believe the SMALL BLOCK stands are the same 67 to 72. The 68 to 71 BIG BLOCK stands do have a dip as mentioned by Texas Firefighter to clear the exhaust manifolds. I believe there is some clearance problems using small block stands with a big block and headers. I don't know for sure as I have used only 72 stands.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
