09-25-2005, 11:19 AM | #1 |
SWB 4X4 CLUB
Rear end
I need help. I am removing the gears from a GM 12 bolt. I got the cover off and the oil out. Also the four main bolts and caps are off. I am told there are c clips to slide the axels out. I am either blind or am looking in the wrong place. I need to know what else I need to do to get the carrier out. IE, where are these c clips located and how to remove them, and if this will free the carrier.
Thanks Jason |
09-25-2005, 11:36 AM | #2 |
PROJECT 7DEUCE
You need to slide the axle shafts in just slighty to take the side pressure off the clips.. Use a magnet if you have one to aid in not loseing the clips into the carrier..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-25-2005, 11:58 AM | #3 |
Member #1049
Jason,
You need to rotate the carrier and look for a 7/16headed bolt thats all by itself.. its actually a "pin" that holds the spider gear shaft.. remove it.. Hopefull it will be whole (they sometimes are broken) it should be about 2 inches long with threads near the top and a round pin for the rest.. if that is succesfull them slide out the shaft.. then you should be able to push in each axle shaft a little .. the C-clips should just about fall out... Here is a link to some pics that may help C-clip stuff |
09-25-2005, 12:05 PM | #4 |
you have to pull the bolt holding the center shaft and remove the shaft on the spider gears so the axles WILL push in to get to the c clips. The c clips are located on the ends of the axles. after they are removed the axles will slide out. Here is a pic to show you what to look for.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!! |
09-25-2005, 03:01 PM | #5 |
SWB 4X4 CLUB
rear end
thanks to all for the help. I will give it a try.
Jason |
