Old 09-27-2005, 12:48 AM   #1
hotrodhomi
hotrodhomi's Avatar
Brake help needed.
What causes a noise, similar to air filling a tank, when braking? It sounds like it is coming from under the dash but it could be in the engine compartment. The break peddle pressure feels firm. But I can tell that it is slowly going away.
hotrodhomi is offline   Reply With Quote
Old 09-27-2005, 01:28 AM   #2
Muddytazz
JMR Offroad
Muddytazz's Avatar
Sounds like your master cylinder is going out and that sound that your are hearing is the hissing sound coming thru the firewall where the push rod goes thru.
Muddytazz is offline   Reply With Quote
Old 09-27-2005, 04:22 AM   #3
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I don't think it's your master cylinder. I had the same problem and it was my brake booster. Read this article to check yours to see if it's going bad http://73-87.com/7387garage/chassis_...on/booster.htm
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 09-27-2005, 09:24 AM   #4
86 GMG
have you hooked up any vacuum hoses that wherent before i did this once on my truck and everytime i steped on the pedal it hissed like you discribe the best i could figure out was it has something to do with is a towing brake booster storage bvall that isnt there anymore i just disconnected it again and have been driving ever since i will keep track of this to learn something also b/c i really would like to know for sure
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 09-27-2005, 09:29 AM   #5
hotrodhomi
hotrodhomi's Avatar
I don't think that it is the master cylinder because I have good peddle pressure. The more I think about it, the more if feels like the vacuum boost is going out.
Old 09-27-2005, 09:45 AM   #6
86 GMG
have fun changing that out keep us posted on how it turns out
Old 09-27-2005, 10:15 AM   #7
hotrodhomi
hotrodhomi's Avatar
is it hard to change? how long should it take?
Old 09-27-2005, 02:05 PM   #8
Muddytazz
JMR Offroad
Muddytazz's Avatar
If your brake booster was going out, you would feel like you have MANUAL brakes (hard to press pedal) soft/spongy pedal feel is a sign of m/c problems.
Old 09-27-2005, 02:46 PM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If it sounds like air being pushed out, it will mostly likely be your booster.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-27-2005, 03:29 PM   #10
hotrodhomi
hotrodhomi's Avatar
So...is it hard to change? How long should it take?
Old 09-27-2005, 06:34 PM   #11
Muddytazz
JMR Offroad
Muddytazz's Avatar
If your going to change the booster, its only a 30 min change. Unbolt m/c from booster, disconnect the pedal pushrod from booster from under the dash, remove vacuum hose and unbolt the booster from the firewall.
Old 09-28-2005, 01:40 AM   #12
79BIG10
79BIG10's Avatar
On this link it tells how to remove and install. http://73-87.com/7387garage/chassis_...on/booster.htm
