I pulled the grill out of my 72 chevy, ( egg crate looking grill ) I want to paint it black. What type paint is best to use? ( I will be useing spray paint cans ) And what is the best way to prep it? Also do I need primer? If so what type? I do not have a paint sprayer. Will be useing cans, semi gloss black for final color.
So what do you guy recomend? I have seen some painted before with the paint peeling off. I am trying to avoid this. Sam
72 LWB chevy truck. Pasadena, Texas |
Between Trucks...
i just hosed mine with rattle cans, flat black faded a bit but no peeling...
if you're concerned give it a couple coats of primer first...
Beat it to fit, Paint it to match... ![]() |
i just did this and i used a brand of paint called PLASTI-KOTE
it turned out fairly well. i first used primer then the gloss black and then i also used some clear cote i think it turned out fairly well. i also put on several cotes of each and hopefully this will avoid the peeling. i will post a pic when i get a chance
1972 C/10 LWB 1972 K/5 Blazer |
1969 Custom 30 wrecker
After the grill is cleaned (soap and water) and just prior to painting, clean with carb or brake cleaner to remove any lasting wax or grease. I would lightly prime and then spray with Krylon's semi flat black. You should have no peeling problems.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Any suggestions for painting an egg-crate grill to make it look like a new one? Mine is all in one piece, but it's very faded.
I would spray it with an argent silver color which is semi flat and I believe used on rally wheels. If you can find the correct shade of silver, it should look like new when done.
