09-30-2005, 07:19 PM | #1 |
shocks for lowered trucks....
Question about shocks. I have a 84 swb that I want to lower in the rear. I currently installed the drop hangers but need to get the drop shackels in. Before I do that I know the stock shocks won't work. Is there a shock # from another application that will work in the rear of my truck that I can get @ autozone or similar parts store???? I don't want to drop big $ for kyb's or nitro's just something that will work and will be available.
John
Locab36 1936 low cab 1/2 ton 1956 BMW R25/3 1968 Moto Guzzi V7 1969 BMW R100/2 1986 Silverado SWB 2007 Harley FLHTP 2011 GMC SWB 4x4 Z71 http://www.flickr.com/photos/locab36...7623329816080/ |
09-30-2005, 07:33 PM | #2 |
Insert Witty Text Here
I don't have an answer for you, but i wanted to point out that Western Chassis and other make shock relocators.
Slonaker |
09-30-2005, 11:21 PM | #3 |
I used stock front shocks for a 73-87 4wd burb/blazer/truck on the rear of my 74. I had to drive out the steel inserts on the bottom end so the larger stock bolts could be used.
They were the best compromise for compressed & extended length that would work @ my ride height (Western Chassis flip kit for a 8-leaf HD spring pack, BellTech shackles & WC shock extensions). They have worked since summer of 03.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-30-2005 at 11:22 PM. |
10-01-2005, 07:34 PM | #4 |
i use late 70's chevy van shocks a old hotroder told these work perfect
10-02-2005, 12:05 AM | #5 | |
So many questions, so little time... Slonaker |
10-02-2005, 07:17 AM | #6 |
I have 4" inches of drop in the rear. Drop spring hangers and shackels. Keeping all the leafs.
John
10-03-2005, 06:16 PM | #7 |
I have a brand new set of Doetsch shocks for rear trucks with 4" drop NEW IN THE BOX $90 shipped
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
