Old 10-01-2005, 11:26 PM   #1
76bonanza
76bonanza's Avatar
wheel question
I have rallys 15x8 6 lug what is the bolt pattern 6-5.5 or 6-5 also anyone know the backspacing or how to figure it?
One more thing any good places to get deals on rims? for our trucks?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 10-02-2005, 03:48 AM   #2
4x4Poet
Get a tape measure or ruler. Measure across the hub opening to determine whether it is 5.5" or 6.5".
Then place the rim on its back upon a flat surface. Measure from the flat surface to the back of the hub opening. That is the backspacing. You can also stretch a straight edge (ruler, 2x4, whatever) across the back side of the rim from rim lip to rim lip and measure from the rim lip plane to the back of the hub opening. That's the more accurate method to measure backspacing.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 10-02-2005, 09:05 AM   #3
1STtimePRo'71
1STtimePRo'71's Avatar
http://128980.brightwebsite.com/lug_bolt_patterns/
-Cory
1967 2 Wheel Chevy
1STtimePRo'71 is offline   Reply With Quote
Old 10-03-2005, 08:59 PM   #4
jamesi20
jamesi20's Avatar
that's not the right info for my 70 c-10 2 wheel drive...it says 5 on 5 and 1/2" lug nuts but my truck which I am the second owner of has 6 lug with 7/16 lug nuts
jamesi20 is offline   Reply With Quote
Old 10-03-2005, 09:33 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
6 lug Chevy trucks are 6 on 5.5 inches. If your wheels are factory 4x4 rallys from 73-87, like most guys run, they have about 4.25 inches of backspace and a width of 8 inches.
Jamesi20, you are correct, a 70 model does indeed have 6 lug pattern with 7/16 studs. They went to the larger 1/2 inch studs when they went to 5 lug in 71.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
