Old 08-27-2002, 12:24 AM   #1
dbenamati
dbenamati's Avatar
Help...no brake lights
For some reason I have no brake lights. I have 4 ways and turn signals, changed the bulbs and followed the wiring the whole way back to the cab with no problems. Where does the wiring go once it gets into the dash? Anyone have this problem before? Thanks, Dave
Dave Benamati
Hughesville, PA USA
dbenamati is offline   Reply With Quote
Old 08-27-2002, 12:28 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Check the plug on the brake pedal, also the wires on the plug.
Old 08-27-2002, 01:11 AM   #3
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
sounds like the brake light switche went south, problem could also be in the column as it uses the same circuit as the turn sigs and that's where everything is split up....if the switch checks out OK, I'd pull the wheel off and make sure all the connections are good and check for power with a test light.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 08-29-2002, 12:26 PM   #4
dbenamati
dbenamati's Avatar
Thanks Fellas
I replaced the switch and tighened the harness (horseshoe) under the wheel and now they work, I don't know what one fixed it but I appreciate it just the same. Thanks again.
Dave
Dave Benamati
Hughesville, PA USA
