Front Coilovers from FatMan
I just finished putting on my IFS kit w/coilovers that I got from FatMan Fabrications. I have to say I love the polished stainless upper and lower tubular arms. Next weekend I'm going to install the rack and pinion steering so more pics to come.
That is very sweet. Does the fat man kit have provisions for the rack and pinion?
Got a link to this? |
Yeah it all came together. Their website is www.fatmanfab.com They always have adds in classis trucks magazine.
All Praise RANDY!!
whats the deal with the crossmember? is it a direct bolt in? or weld in?
Looks sweet though! ![]() |
It bolted right in. Just had to drill a few more holes in the frame.
LS1 Lover
That is really cool I thought about using corvette front suspension but I like that bolt on idea alot more
All Praise RANDY!!
what kind of drop in the front are you lookin at getting out of that? What is the $$$$ of that bad boy???
#8 | |
LS1 Lover
It should be between 4-5 inches but you can go lower if you get dropped spindles. The whole kit with s/h was $2800. A little more than I wanted to spend on my suspension but I really like the look. I just have to save a bit longer for my engine now.
You can use the stock mounts but you have to fab a spacer for them to work cause the new crossmember sits lower. They have tubular mounts available but they are weld in so I'm not sure if I can use them since I don't know how to weld. Last edited by raidermanny; 10-04-2005 at 12:52 AM. |
Looks good, raidermanny. I too have the Stage III kit (couple pictures in link in sig). Interested to see how yours sits with the weight on the front end. I think I'm going to need different springs with the LS1 and fiberglass front end.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
68LSS1 I'm glad I found someone else with this kit. I'm gonna be PMing you with some questions if you dont mind. I wanted the same rear kit that you have but thought it was a little to advanced for my skills.
#12 | |
Looks awesome Raidermanny!
68LSS1. Are you installing buckets on your truck? I want to do the T-56 upgrade but would like to retain my bench seat. The shifter linkage location might change my plans though... I didn't realize it was that far towards the rear of the cab. Doug |
Yes I'm using buckets, benches don't work well with 5 point harnesses. Note that I have moved the engine as far back as I can and also it is possible to get a T56 with the shifter mounted on one of the forward pads (they actually have three different spots where it can be). Unfortunately as of now there are no kits to move the shifter, so you must buy the tranny with the shifter in the location you desire from someone like 5speedtransmissions.com (they sell 6 speeds also).
#15 |
^ Very cool! I noticed in the pic there was a square block off plate on top of the tranny (roughly in the center), that must be for the shifter if you decide to have it more forward. Thanks! That makes this upgrade a little easier. Doug
#16 |
Just Don't Stop!
![]() Join Date: Feb 2004
Any idea how much weight you are saving with that front end?
1968 C10 build in process TT LSA/6L90e/9" |
#17 |
No, we had a thread around the time when I first joined this forum with me weighing the Fatman stuff and others weighing the stock stuff but I never saved it.
#18 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Very nice set-up ...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#19 |
I would guess it saves about 175 lbs
#20 |
Just Don't Stop!
sure seems like alot. I guess it's possible though.
#21 |
67 is sold
That looks great!!!
#22 | |
I would of guessed about the same. I can pick up the crossmember with the a-arms and brakes on. Plus you loose the gear box or actually I guess it would be more correct to say that the rack and tie rods weigh less than the gearbox, tie rods and idler/pitman arm. Plus you should get about 5" of drop without dropped spindles.
#23 |
Here it is with the rack and pinion and sway bar on.
#24 |
Any idea what the rack is from? Mustang II or something else? Looks good. How bout the spindles and brakes? Thanks
Also, what size bolt is that going through the lower a-arm bushing? I wouldnt think a single-shear setup would work right there, wouldn't figure it would be strong enough. Must be though, or they would be breaking and Fatman would be in some trouble. Last edited by Portmod7; 10-12-2005 at 08:22 PM. |
#25 |
"Bondo, just say no!"
man that setup looks sweet, worth every cent. so clean easy to work on. are they adjustable coil-overs?
"WORK NOW, SLEEP WHEN I'M DEAD, SPEND EVERY PENNY I MAKE" 69 C-10 SWB Stepside (ground up resto in progress) 86 Yugo 69 Honda pc50 moped see my work @ http://www.myspace.com/inkorperated free site for pics Last edited by tattoo; 10-12-2005 at 08:56 PM. |
