Old 10-04-2005, 10:06 AM   #1
phlegm
Still Green but learning
phlegm's Avatar
Working on the Valve cover, found a mystery wire
Not sure if this falls under electircal, since its not an issue of the wires not working.
While working on the truck last night I found 3 wires and their termination clip all taped to the AC Compressor Bracket, not connected to anything. The wires run down the top of the engine just inside the Valve ccover in that grove, and are attached to the block with Clips.... any idea what this is supposed to connect to?
Thanks in advance
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 10-04-2005, 11:49 AM   #2
farside847
farside847's Avatar
Does your temp guage work? I seem to remeber the temp sender is on that side of a SB
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 10-04-2005, 12:45 PM   #3
shaneschevys
Its always something!
shaneschevys's Avatar
what color are the wires? Some trucks had 2 temp senders on each side of engine one for the guage & one for the temp light in the dash. If your truck is a fact air truck there should be a small solenoid on the side of your carb that idles up your engine when you turn your a/c on. Hope this helps you out.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 10-04-2005, 12:56 PM   #4
phlegm
phlegm's Avatar
Both are good suggestions, i will run the both down. I do not ahve a guage cluster, but it could be the dummy light.
I will have to check on the carb solenoid too. would that run directly to the compessor, or somewhere else, I assumed my wires ran to my fuse panel but if it is the ac stuff I could probably trace it back to the the unit somehow.
Anymore suggestions would be welcome!
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 10-04-2005, 02:58 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
None of these trucks ever came with 2 sending units. Not originally anyways. The only original location for the temp sending unit for a small block 67 - 72 truck is in the passenger side head between #1 and #3 cylinder exhaust ports.
This may be for the vacume advance delay crap that they had as primitive emissions... Not sure since I have very few details, I think that was mounted on the passenger side of the intake with a relay or something on the firewall.
Old 10-04-2005, 05:27 PM   #6
phlegm
phlegm's Avatar
Thanks again guys.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 10-04-2005, 05:28 PM   #7
bucket
bucket's Avatar
[QUOTE=Longhorn Man]The only original location for the temp sending unit for a small block 67 - 72 truck is in the passenger side head between #1 and #3 cylinder exhaust ports.
Or in the intake manifold near the oil fill tube in the case of a 67 327.
bucket is offline   Reply With Quote
Old 10-04-2005, 05:42 PM   #8
70short/step
70short/step's Avatar
Isnt #1 and #3 cylinder exhaust ports located on the drivers side of the engine??
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 10-04-2005, 06:01 PM   #9
farside847
farside847's Avatar
My temp sensor is on the drivers side from the factory. 1971 307 V8
Old 10-04-2005, 07:13 PM   #10
Longhorn Man
LOL...yes. I ment drivers side..the caddy engine has #1,3,5,&7 on the passenger side. I had it pictured in my head properly...just didn't word it correctly.
As for in the intake... I've never seen that, but my 67/68 hands on portion is minimal.
Old 10-04-2005, 09:19 PM   #11
neonlarry
neonlarry's Avatar
Trucks equipped with a TSC system did have two temp sending units. Gauge one in D/S head TSC controll on in the P/S head.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 10-05-2005, 08:32 AM   #12
phlegm
phlegm's Avatar
I took a look at the wiring diagrams in my haynes Manual. It was late when I got around to it but I think the temp sensors only have 1 wire going to them that I can tell. The one I found is has 3 wires. It looks a lot like the wiring for my alternator, I thought maybe it was pre rebuild and they replaced it, but it runs down the PS with clips there for it.. alternator is on the other side.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 10-05-2005, 11:53 AM   #13
farside847
farside847's Avatar
What engine do you have? The stock location of the alternator on a SB is on the driver side too. I have a wire bundle that goes down along the valve cover then splits off to hook up to the alternator and the temp sender. 4 wires I think (correct me if Im wrong)
Old 10-05-2005, 02:11 PM   #14
phlegm
phlegm's Avatar
Sb 350 from a 71, thats why I dont think its for that application. I am surprised that it has 2 sending units for the temprature.... gues I am just going to have to go digging for a termination point to see what it is really for.
I have to go back in anyway, the old gasket didnt set right when I replaced the valve cover, I drove it for a half hr last night and it started oozing once the oil heated up o well, back at it.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 10-05-2005, 02:14 PM   #15
phlegm
phlegm's Avatar
What is TSC system? and would it be on my box sticker or sales receipt?
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 10-05-2005, 03:25 PM   #16
neonlarry
neonlarry's Avatar
Actually its TCS(my mistype) for transmission controlled spark. It has a switch in the transmission, a relay on the firewall, a temp sensor in P/S head and a solenoid on the intake manifold. It shuts off the vacuum advance in the lower forward gears, the temp sensor overrides this when the engine is cold.
Old 10-05-2005, 03:32 PM   #17
phlegm
phlegm's Avatar
I have a stock 3 spd. this sounds more like something you would put in a Auto Tranny.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 10-05-2005, 04:06 PM   #18
neonlarry
neonlarry's Avatar
You are correct.
Old 10-05-2005, 04:28 PM   #19
phlegm
phlegm's Avatar
OK back to doing a hunt and peck for the socket.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 10-06-2005, 12:05 AM   #20
kbs71
71 rustless in texas
kbs71's Avatar
Sounds like your truck use to have an under dash A/C unit installed at one time. My 71 has the exact same setup your refering to and it went to the A/C compressor that use to be there when the old under dash unit was installed.
"The secret to creativity is knowing how to hide your sources."
"No one really listens to anyone else, and if you try it for a while you'll see why"
71 C-10 LWB presently in a perpetual state of disassembly
'96 Toyota (my work car)
'04 Mustang Convertable (wife's car & other money pit)
Latest aquesition and why my trucks still in the garage covered with junk..
2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck
FAQ here
VENDORS here
SUPPORT THE BOARD here
My second favorite SITE
kbs71 is offline   Reply With Quote
Old 10-06-2005, 08:24 AM   #21
phlegm
phlegm's Avatar
Shouldnt be, I have factory air. but it does look like the same wiring.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 10-06-2005, 04:40 PM   #22
patrick66
crazy about dem trucks!
patrick66's Avatar
Have you checked the connection for power? If so, does it come on when you turn the ignition on, or is it constant? It's sounding to me like an a/c power source, as said earlier. You may be able to simply cut it off at the source and rid yourself of the problem.
patrick66 - '67 C-10
patrick66 is offline   Reply With Quote
Old 10-07-2005, 08:19 AM   #23
phlegm
phlegm's Avatar
My buddy that rebuilds 350s for his Pontiacs of the same era, said it looks like the TCS harness to him. That it is possible when they did the reubuild the harness included that connection although it was not needed. so they just taped it off incase he ever went automatic. We dont know for sure but that is as good a theory as any.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 10-07-2005, 06:01 PM   #24
larry may
My ole heap has same wires.Do not remember what they went to . Alternator I think , Used to have a six cylinder, Wires were ran a bit different. Than for what is in there for an engine currently. Probably was for an idiot light of sorts and for sure one was for temp gage.
larry may is offline   Reply With Quote
Old 10-11-2005, 04:14 PM   #25
WB72
Before and After
WB72's Avatar
It possibly may be a Engine Block Heater cord...
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
