Old 10-04-2005, 06:29 PM   #1
71Shortbed
71Shortbed's Avatar
Question Engine missing (well, I know where it is)
I've got a stock 307 with an Edelbrock 500cfm and performer manifold. It's been running great until yesterday. It started running rough like its got a plug wire off. I replaced the plugs, wires, points, rotor, condensor, and cap. Set the dwell to 30 degrees and timing to 8 degrees and it's no better. Checked all my vacuum lines. Still runs rough and sputters and backfires when I step on it.
Any ideas what it could be?
71Shortbed is offline   Reply With Quote
Old 10-04-2005, 06:59 PM   #2
krue
Designated A-hole!
krue's Avatar
Can u tell which cylinder is not firing? I had problems with mine until I replaced a cracked exhaust manifold of all things.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 10-04-2005, 07:06 PM   #3
71Shortbed
71Shortbed's Avatar
I can't tell for sure but it appears to be on the drivers side. 1,3,5, or 7. Idles smooth and normal but pulling up my driveway it shudders and runs rough as hell. Should I do a compression test?
Old 10-04-2005, 07:09 PM   #4
larry may
WATER IN FUEL? Blown Head gasket? Float in carb needs adjusted? Good luck . POINTS GAP TO WIDE ? Cam sprocket failing ? Good Luck
larry may is offline   Reply With Quote
Old 10-04-2005, 07:15 PM   #5
krue
Designated A-hole!
krue's Avatar
May want to pull the plugs and check them. Any Haynes manual will have a TS guide for plugs.
www.daveramsey.com
Old 10-04-2005, 07:23 PM   #6
chops333
take off rocker cover start engine see if all rocker arms move smallblock chevy notorious for wearing out cam hope this helps
chops333 is offline   Reply With Quote
Old 10-04-2005, 07:27 PM   #7
71Shortbed
71Shortbed's Avatar
I pulled a few plugs. They are black and sooty and so are the pipes. Maybe its just running too rich. When I stand on it I hear the exhaust really crackin and it starts to cut out. I'll dig into the carb next and see if I can lean it out a little.
Old 10-04-2005, 08:11 PM   #8
4tiresngas
An American Soldier
4tiresngas's Avatar
71Shortbed, why did you set the timing to 8 degrees advanced? The reason I ask is because when I got my truck it was 8 degrees advanced. I set it back to 0...where I thought it should be. It fires right up. Was that wrong?
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 10-04-2005, 08:17 PM   #9
71Shortbed
71Shortbed's Avatar
My 71 Service Manual says 8 degrees for a 307 with automatic and 4 degrees for a manual. I was running it at 12 degrees with no problems. I went back to 8 just to eliminate that as a possible issue when it started running like hell yesterday. More advance should give you more power up to the point where it knocks and become a bad thing.
Old 10-04-2005, 08:20 PM   #10
truckdude239
truckdude239's Avatar
does it only do it when you step on the gas? if so it might be an accerateor pump in the carb
Old 10-04-2005, 08:26 PM   #11
71Shortbed
71Shortbed's Avatar
I thought about the carb pump but it does it all the time. I thought about trash in the filter but generally that means it would run OK when it starts and die out when the bowl runs dry. Maybe its my mechanical pump going bad.
Old 10-04-2005, 08:26 PM   #12
larry may
Like chops333 said . Also look for BENT PUSH RODS.
Old 10-04-2005, 08:28 PM   #13
71Shortbed
71Shortbed's Avatar
Thats my next step. I'm going to pull the covers and make sure my rockers are moving. Thanks
Old 10-04-2005, 08:31 PM   #14
cdowns
cdowns's Avatar
i'd set the timing at 0//the dwell needs to be 33-34//plugs gapped at .035
Old 10-04-2005, 08:48 PM   #15
71Shortbed
71Shortbed's Avatar
I'll try it but why 0 degrees when the manual says 8? Do you think I'm getting too much advance at higher rpms? My vacuum line is on the carb port that only pulls a vacuum above 1600 rpm. All this was workin fine at 12 degrees until I went for that afternoon spin...
Old 10-04-2005, 08:53 PM   #16
jamesi20
jamesi20's Avatar
I don't think "0" degrees is going to help 8 degrees sounds more like it.you could have a cam problem as these were notorious for lobes wearing,that is if it is a stock motor
jamesi20 is offline   Reply With Quote
Old 10-04-2005, 08:57 PM   #17
chops333
also did you disconnect vac at the vaccuum advance when you set timing just a thought
Old 10-04-2005, 08:57 PM   #18
71Shortbed
71Shortbed's Avatar
I'm starting to suspect the cam. It's stock with about 140,000 miles on it. Dangit That's not a 3 beer job to replace a cam.
Old 10-05-2005, 09:30 AM   #19
motocrosschump
Take the valve cover off that side and start and see how far the lifters are lifted.
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 10-05-2005, 10:10 AM   #20
lloyd k
lloyd k's Avatar
timeing chain , cam and a good lifter puller
67 swb gmc,big block cadillac powered,400 turbo,2.73 ratio and disc brakes-basically a frankenstein of many parts-
lloyd k is offline   Reply With Quote
Old 10-05-2005, 01:12 PM   #21
mrein3
mrein3's Avatar
Not a three beer job but if you're in a hurry you can be staring at a camless engine in about an hour. Of course clean-up of parts and reinstalling everything takes about 3 more hours.
Pull the valve covers first. Check for rockers that don't move as high as the others. Every flat cam I ever had was obvious with the engine running and the valve cover off.
The engine that was in my truck when I bought it stumbled and coughed when I was trying to make power (pulling the boat or passing on the highway). That time I had two exhaust valves that weren't working any more. A compression test will tell you about that if your cam appears to be ok.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
