Old 10-08-2005, 12:58 AM   #1
71Dragtruck
71Dragtruck's Avatar
Thumbs down Bad news tonight
Well you know that sick feeling you get when things are really bad? I have that, truck started to run bad on me, sounded like a ignition problem. Went through everything with no luck, just got worse. Well then I could hear a noisy lifter and thought maybe one of my polylocks came loose, so I pulled a valve cover. This is where my stomach sank , one of the connector link tabs on my roller lifters came loose, and the bar came off. Two lifters spun sideways and ate a lobe off my roller cam $$$$$$$$$$$$$$$$. I took off the intake and yes cam is toast, can't even get the lifter out the top, it didn't even make a funny noise, just ate the cam like a bread stick. The whole engine has to be tore down and gone through, I could just die . Likely going to be over $1000.00 time I'm done. Well thank's for the shoulder, I have to go tell the kids that they are going on a strick diet.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 10-08-2005, 01:01 AM   #2
1STtimePRo'71
1STtimePRo'71's Avatar
Oh No! I'd hate to be those kids, But I would hate to be you more. Sorry to hear this happened.
-Cory
1967 2 Wheel Chevy
1STtimePRo'71 is offline   Reply With Quote
Old 10-08-2005, 02:03 AM   #3
stllookn
Saving 1 truck at a time!
stllookn's Avatar
OUCH! Any idea how or why this happened? I know the feeling. I once transplanted a new high performance 283 in my '59 panel. In a week it put a wrist pin into the cylinder wall and started smoking like mad. I had to pull it and rebuild it immediately. I was not happy...it was supposed to have been a good engine and it test drove great before I bought it.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 10-08-2005, 03:47 AM   #4
djracer
djracer's Avatar
71dragtruck
I hate to here of your mis fortune! You might want to get your cam specs and have Chet Herbert grind you a new one! He is really resonable and does great work! I think his rollers start at 159.00! I had one of his cams in my camaro drag car and was very happy!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-08-2005, 06:47 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Woah, dude... I feel your pain man.
However;
At least you are still able to laugh, or at least make us laugh.
Old 10-08-2005, 08:33 AM   #6
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Sorry to hear about your engine. I just got mine running again, so I can imagine how you feel after all the time and money expended.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 10-08-2005, 09:06 AM   #7
Yukon Jack
Yukon Jack's Avatar
Bummer. I lucked out and when I had engine troubles after fire up it luckily didn't damage the cam or any of the pistons. Good luck getting it back together.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-08-2005, 09:07 AM   #8
72MARIO
72MARIO's Avatar
That sucks. It's sleeping time for it soon anyways right ? Now you can make it better and faster.
Well at least look at the bright side you didnt have to pick up the pieces and get towed home.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 10-08-2005, 09:23 AM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
However;
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-08-2005, 09:45 AM   #10
nitor
Too many projects
nitor's Avatar
Sorry for you.
Jim
'55 Chevrolet Pickup
'56 Chevrolet Belair
'04 Chevrolet Astro
'95 Chevrolet Blazer
nitor is offline   Reply With Quote
Old 10-08-2005, 09:50 AM   #11
tnblazerk5
User #12137
tnblazerk5's Avatar
ouch
tnblazerk5 is offline   Reply With Quote
Old 10-08-2005, 10:04 AM   #12
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Originally Posted by LUV2XCLR8
Me too.
Good luck in the rebuild.
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 10-08-2005, 11:27 AM   #13
masterbeavis
Having issues
masterbeavis's Avatar
I know the aww sh__ feeling. the first motor I tried doing things right on wound up being more of a PITA than the motor I cheated and took every shortcut known to man. I wound up pulling that motor apart 4 times, each time was a minimum of $400 in parts replaced. Finally solved the problem when I burned a hole in two pistons.
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 10-08-2005, 07:41 PM   #14
71Dragtruck
Tab on the side of the lifter came loose.
Sponsored by:
Hard Candy Customs
Old 10-08-2005, 07:42 PM   #15
71Dragtruck
Originally Posted by djracer
71dragtruck
I'll have to check him out, thanks.
Sponsored by:
Hard Candy Customs
Old 10-08-2005, 07:46 PM   #16
71Dragtruck
Yes allready planning a bigger cam, intake and a full race port and polish from the current street strip job and a set of H-beam rods to spin it to 7200RPM. This time S#@*'s going to fly when she let's loose.
Sponsored by:
Hard Candy Customs
Old 10-08-2005, 09:32 PM   #17
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Bummer but at least you were not pickin up those blown up tranny pieces that had to suck..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-08-2005, 10:32 PM   #18
jlmtrout
Been there, done that, got the t-shirt to prove it! That happened to me two years ago the week before my vacation trout fishing in the Ozarks. That was the third time I had to rebuild my engine. First time, the machine shop that pressed my wrist pins in put spira locs on the ends of the pressed in wrist pins, result: broke connecting rod in three pieces at the crank had to replace block and crank and one rod and piston. Second time, wrist pin walked and scored the cylinder, had to sleeve it. Last was the lifter link bar broke and lifters rotated in bore and ate the cam (had to replace the complete set of lifters-$475 plus another $300+ for the cam). If I had been hot rodding it, I wouldn't have felt so bad. But this is my daily driver and it really hurt to have to go through all of this in about a year and a half. Makes you want to cry. Sometimes bad things happen to good people. Sorry you're having my kind of luck. Hang in there, it has to get better. (Can't get much worse). Good luck and keep on truckin'................Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
