Old 10-12-2005, 10:35 AM   #1
Steven B
Steven B's Avatar
Rag Joint replacement
Any one replace a rag joint? How do you get the round studs off the coupler?
Steven B is offline   Reply With Quote
Old 10-12-2005, 11:13 AM   #2
shifty
Questionable
shifty's Avatar
I bought a replacement kit the other day from local auto chain because I'm doing steering upgrade (pitman/idler arms, tie rods, adding power steering).
I took my coupler off from the shaft and went out to pick up a new rag joint for $6 from Advanced Auto Parts. Inside the kit, it looks like the studs are threaded on the side opposite the smooth end - and I know exactly what you mean, it looks impossible. There has to be a good way to get them on and off, but I don't know it and my manual doesn't say.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 10-12-2005, 11:17 AM   #3
Steven B
Steven B's Avatar
It looks like the end of the threaded part has been peened(?) over like a rivit or something. My replacement rag joint has threaded ends on the round studs, but can't figure out how to remove them.
Old 07-02-2010, 02:25 PM   #4
max71c10
max71c10's Avatar
Re: Rag Joint replacement
did u ever find out how to git the bolt with a threaded side and a smooth side on the rag joint off? i really need to know im tryin to drive my truck by tonight
max71c10 is offline   Reply With Quote
Old 07-02-2010, 02:38 PM   #5
msgross
msgross's Avatar
after 5 years he might have given up... good luck though...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-02-2010, 02:47 PM   #6
leddzepp
Moderator
leddzepp's Avatar
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-02-2010, 02:48 PM   #7
max71c10
max71c10's Avatar
can anyone help or get help? >:/
Old 07-02-2010, 02:49 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Put the smooth side in a vice to hold it tight. Use a wrench to unbolt it. Simple 5 min job. Here is a side view of mine after I did it. The entire assembly comes off of the steering box. Loosen the collar and it slides right off the splines. You re-use the metal frame (coupler) and replace the rubber disc (rag joint) and hardware. The kit is avaiable in the HELP section of most major auto parts stores for about $10.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-03-2010, 02:42 AM   #9
max71c10
max71c10's Avatar
thanks for picture and info but the 2 bolts with smooth tops dont have nuts on the ends the back of the bolts where the threads are just turn when i turn the smooth side. ill get a pic of it saturday afternoon, so please look at this thread around that time.
Old 07-03-2010, 03:02 AM   #10
leddzepp
Moderator
leddzepp's Avatar
The HELP kit comes with new hardware. You can grind/cut off the old bolts and attach the new rag joint with the supplied hardware. In the future, should you need to replace the ragjoint again, its a simple matter of unbolting the assembly.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-05-2010, 03:29 AM   #11
max71c10
max71c10's Avatar
yep, thats what i did. i grinded the back of the bolts, pulled em out, then replace the sum*****. its workin now, i appreciate yer help.
