Old 10-15-2005, 12:30 AM   #1
autobodyman2
spark plug order
Can anyone supply a plug wire diagram. Its for a 350. I just bought a truck from a kid and i dont think he got them hooked up right.
autobodyman2 is offline   Reply With Quote
Old 10-15-2005, 12:51 AM   #2
Russell
Professional Grade
Russell's Avatar
Firing order is 18436572 Driver's side cylinders are 1, 3, 5, and 7, with number 1 being the cylinder closest to the rad, and passenger's side is 2, 4, 6, and 8, with number 2 being the cylinder closest to the rad.
It doesn't really matter which pole you set as number 1 on the distributer, so long as you set number 1 directly above the rotor's pole. Typically, most people set number 1 as the second pole from place where the power cable goes into the cap, going clockwise
Make sure that you have cylinder 1 at top dead center before you do anything though, otherwise your timing will be way off.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-15-2005, 01:09 AM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
Here you go. This will make it simple.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 10-15-2005, 08:37 AM   #4
autobodyman2
Thanks alot guys. Im going to check the wires, then the timing before i fire it. Gas was shooting out the top of the carb, and the kid I am buying it from is an idiot. I hope he didnt mess anything up too bad.
Old 10-16-2005, 09:17 AM   #5
koreric75
83C10SWB
koreric75's Avatar
Re: spark plug order
I had a problem with gas coming out of the top of my Holley when i first got it, it just need adjusted, it was real easy but i broke the gasket that sits under the valve nut and had to make a new one.
Koreric75
2003 Suburban Z-71 4x4
5.3L
83 C10 SWB FOR SALE
350ci/700Raptor Jr
Picture&Progress Page
koreric75 is offline   Reply With Quote
