Old 08-28-2002, 11:49 PM   #1
big.l.a
big.l.a's Avatar
Spacing between header & Starter ??????
Had to replace my starter today.I noticed that there was only about a 1"-11/2" between the header and the starter. My Q is will this affect the life of my starter, and what's the best solution
to correct this?????
71 C10 LWB With
Edelbrock 7101& 1406 Carb
Accel HEI Blue Print
Accel 8.8 Wires
Soon to have possi &
186 Camel hump heads
Dropped 2-1/2F&4R
Dynomax Headers
Duals Flowtech Aftburners
Tonneau Cover Frm 89 F150
79 Monte C
big.l.a is offline   Reply With Quote
Old 08-29-2002, 12:02 AM   #2
GreenMystChevy
I personally do not have headers but I have heard this problem a million times. It takes a lot off of your starter and when it gets hot from the truck running and you go to start it again after getting your gas or something, it is very hard to start. A lot of companies make heat shields that you can buy that should solve the problem, or at least help it. I'm sure Sumitt, Jegs, or JC Whitney has them but I am not real sure. Good luck and I would recommend getting one. Have a great time!
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 08-29-2002, 12:08 AM   #3
chevy4ever
chevy4ever's Avatar
Yes you need to buy a heat shield, but thats just my opinion. Like he said, it wont FIX it but it will make the *life* of the starter be longer than without it.
email is matthew.solar1984@gmail.com
1980 Malibu Classic 2door(sold) 8-(
2001 Silverado single cab 4.3 V6(stolen and the totalled)
1979 GMC sierra swb stepside 350(sold)
1990 chevy suburban 4x4 350
2001 tahoe 4x4
2001 suburban 4x4
chevy4ever is offline   Reply With Quote
Old 08-29-2002, 12:19 AM   #4
junkyardjohn
junkyardjohn's Avatar
Thumbs up
YEP -- A HEAT SHIELD IS A REALLY GOOD IDEA TO KEEP YOUR STARTER A LITTLE COOLER IF YOU HAVE HEADERS ON YOUR TRUCK. I BUY THE LIFETIME GARRENTEED STARTERS, & STILL HAVE TO REPLACE THEM ABOUT EVERY 16 OR 18 MONTHS, BUT AT LEAST THEY'RE FREE.
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-29-2002, 01:30 AM   #5
chevy4ever
chevy4ever's Avatar
Yeap, if you get the lifetime then who cares?!?
2001 tahoe 4x4
2001 suburban 4x4
Old 08-29-2002, 08:19 AM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Okay, who cares? The guy whose truck won't start because of "heat soak". It won't bother you, if HIS truck doesn't start.
Get the heat shield for the solenoid. It made a difference in mine...in fact, I've not had anymore trouble. By the way, I didn't have any trouble with it until I changed carbs. The old one, an Edelbrock 1405, was running so rich that changing to a new Edelbrock 1901 caused it be be leaned-out and properly fed, so the exhaust gasses were hotter. Anybody got a better idea?
Put the heat shield on it. It's cheap insurance....oh, it's not the starter that gets affected, it's the solenoid! Solenoids DON'T have lifetime warranties.
Member Nr. 2770
Old 08-29-2002, 08:29 AM   #7
kxmotox247
kxmotox247's Avatar
You might try buying a mini-starter just to give you that much extra room.
A heat shield would be a good investment.
kxmotox247 is offline   Reply With Quote
Old 08-29-2002, 08:59 AM   #8
Church
Carolina Classic Trucks
Church's Avatar
A lot of guys around my neck of the woods have the same problem too. We found that if you buy one of the high torque starters that you can rotate it will fix the heat soak problem. Oh yeah, the heat shield will help a little too.
Church is offline   Reply With Quote
