Old 10-15-2005, 10:29 AM   #1
71Shortbed
71Shortbed's Avatar
Power brake question
After the discussions in my previous thread about the "mystery" wire and my proportioning valve I'm wondering if the PO of my truck added power brakes.
Power brakes are not listed in my glovebox, but then power steering isn't either and I have it. There is no brake warning switch on my pedal bracket under the dash and the pedal rod seems a little short.
Would a 71 Custom come with power brakes and steering without it being listed on the sticker?
71Shortbed is offline   Reply With Quote
Old 10-16-2005, 10:53 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Power brake question
Nope, it would be listed.
As for the short rod, when the P.O. installed the booster, he didn't bother to adjust the push rid. Remove the master cylinder and pull the push rod out. You'll see one end screws in and out. Make small increases in size. You'll want to leave a little but of free play. test drive it on the freeway after adjusting....or a long 2 lane black top...what ever. Hold it at 60 for a few miles, and then pull over and check for excesive hear on the wheels...esp the rear. If they ar etoo hot, shorten the rod just a touch.
Old 10-16-2005, 11:03 AM   #3
ckhd
ckhd's Avatar
If it's not on the sticker, it didn't come from the factory.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 10-16-2005, 07:37 PM   #4
uncle
It looks like they used the whole setup from a drum brake truck. That might be most of your problem.
uncle is offline   Reply With Quote
Old 10-16-2005, 07:40 PM   #5
pjmoreland
pjmoreland's Avatar
I assume that you have disk brakes in the front, right? If so, I'm pretty sure you have the wrong proportioning valve installed on your truck.
pjmoreland is offline   Reply With Quote
