10-18-2005, 08:45 AM | #1 |
saftey matters
as some of you know i have been working on a replacement frame for my 86 swb i notice the other night that one of the cab mount brackets on the frame has really big hole in it where the others are about a 2 in circle my ??? is can i just bolt another one on with grade 8 bolts and not have ANY problems in the future if this is not safe enough please tell me and i will work on welding in another piece of metal and then cut out another hole but that sounds like a lot of work compared to the grind, bolt, and be happy. thanks in advance and please give me all your comments on this subject to help me make my mind up with what im going to do.
square body trucks an addiction or an investment either way they consume all my extra time and money |
10-18-2005, 01:38 PM | #2 |
Hollister Road Co.
Re: saftey matters
You can use what is called a flange or frame bolt with a flange nut. The grade for the bolt is grade 8 and the nut is grade C. They should fit very snug in the hole, not so you have to hammer them in but they shouldn't have a lot of slop. Fine thread if you can find them. Use the standard grade 8 bolt torque for that size and it will be should be fine. If you look at the over the road trucks most every frame part is bolted not riveted.
try here for the bolts and nuts. http://www.pointe-products.com/ http://www.barnhillbolt.com/acb26/index.cfm?&DID=7 |
10-18-2005, 03:52 PM | #3 |
www.73-87chevytrucks.com
Re: saftey matters
It "sounds" like someone replace the mount with one from a early model frame.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
10-18-2005, 04:41 PM | #4 |
Re: saftey matters
dwcsr thanks
kaos i believe this brace is the original it is riveted i am just concerned about the hole being too big and causing me trouble with the cab mounts it is a bigger hole than the others. when i got this frame there was a cab on it but just sitting not bolted so i dont know how the cab mount set in the hole. basically my question was will i be safe if i bolt a diffrent bracket on the frame that has a smaller hole in it before i mount the cab up if bolting on another one is not safe enough then i will try closing up the hole somehow just let me know i have some time before i need to really know this. thanks for your help and comments
