Old 10-22-2005, 02:46 PM   #1
steverino66
E-brake/auto trans66
Has anyone solved the problem of mounting a 350 trans in a '66 where the emergency brake mechanism is right in the way? Can this be done without eliminating the e-brake?
I believe my frame is from an older truck but haven't been able to identify it and the crossmember for the original 3-speed manual is several inches forward of the mounting point for the 350. Just moving the crossmember back would not solve the problem of the e-brake bracket/cables running through that spot. Suggestions?
steverino66 is offline   Reply With Quote
Old 10-23-2005, 08:15 PM   #2
Woogeroo
Re: E-brake/auto trans66
the '66 has a different e-brake system than the '60-'65 e-brake.
I installed a '66 and up type system in my '65 which has a 350 eng and 350 tranny in it...
-W
Woogeroo is offline   Reply With Quote
Old 10-24-2005, 12:28 PM   #3
steverino66
Woogeroo-
Thanks - once again you've straightened me out. Guess I'll be scrounging specifically for a '66 parts truck for this if I keep the TH350. I'd read the 66 e-brake was different but didn't know in what way. This confirms I have an older frame under my truck.
Will keep your site bookmarked for reference.
Old 10-24-2005, 06:59 PM   #4
zenish
since the brake cables changed in 66 and the frame is mostly the same to 72,you don't suppose the cables would be the same from 66-72?
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 10-25-2005, 08:13 AM   #5
65StreetCruiser
It Is What It Is
65StreetCruiser's Avatar
The emergency brake setup is the same from 66 to 68. Chevrolet changed from the arm/lever system on the transmission crossmember, 65 and older, to the later style suspended cable in 66. The 67-68 setup was the same, having the emergency brake lever mounted horizontally under the steering column like the earlier body styles. Alot of the hardware for the setup is available from different suppliers. By the way, steverino66, welcome to the board from Louisiana. Kevin
65StreetCruiser is offline   Reply With Quote
Old 10-25-2005, 09:06 PM   #6
zenish
i guess i need to hit the junkyard.it would be nice to have a parking brake again.
1964 c10 short step
1962 econoline van
1989 rs camaro
1975 goldwing
Old 11-08-2005, 06:13 PM   #7
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
My 64 1/2 ton GMC has under dash e-brakearm ,the tranny mounted one was used with some SM-420's not sure which apps.
jgrh64 is offline   Reply With Quote
Old 11-08-2005, 10:39 PM   #8
Woogeroo
if you have the parts inside the rear drums and the lever under the dash - you need the cables which most vendors carry... there is one part, which is a rod that sticks through a hole in the frame under the passenger side that is part of the system of holding the cables in line.
http://woogeroo.home.mindspring.com/...g/ebrake66.gif
That is an image of the '66 type e-brake cable system.
-W
