Old 10-23-2005, 01:10 PM   #1
cadiac
FS 68-72 LW bed & other stuff
Decided to use a later model bed, so I'm selling this one. Someones been working it, -it has small amounts of bondo at the stake holes ?? right side is straight -left side is dented behind where the bondo can be seen. It is not rotted but has heavy pitting in the floor at front. Floor has some dents -tubs have small dents/dings. (I'd intended to Por 15 -coat with Rhino liner type kit the floor) Rear panel has holes cut for bumper braces, -I have another bottom to cut patches out of. $200 --Have a gold LW tail gate thats real decent/no rot $150 --Another LW gate a little dented $40 --left LWB side -has pin holes in wheel arch and some damage/some rust where tub meets inside. $30 --67-68 hood with 4 small dings/dents $25 --67 left fender a little bondo and a pin hole in pocket $25 --pair driver trailing arms from 3/4 $40 --1 in cab tank $25 Email for other pics, Thanks -Steve
cadiac is offline   Reply With Quote
Old 10-23-2005, 02:24 PM   #2
Jakes-66-K10
Jakes-66-K10's Avatar
Re: FS 68-72 LW bed & other stuff
Do you have pics of the tailgate? I may be interested if it has the woodgrain trim.
Jakes-66-K10 is offline   Reply With Quote
Old 10-23-2005, 03:41 PM   #3
cadiac
The gold/nice gate is from a 68,- I should have described it better. It didn't have the woodgrain. The other gate did have it/Bad shape. Trim's all off of both. Will get pics shortly of both gates if you still want to look.
Old 10-30-2005, 12:25 PM   #4
chevykevy
chevykevy's Avatar
Do you a set of spark plug heat shields for the rams horn manifolds. I need the wire loomd for the rear of the engine and under the manifolds too. Thanks.
chevykevy is offline   Reply With Quote
Old 10-30-2005, 02:54 PM   #5
cadiac
No I don't, sorry.
Old 11-22-2005, 12:26 AM   #6
cadiac
bump
Old 11-23-2005, 01:49 PM   #7
Green Machine
Green Machine's Avatar
Put me first in line for the good tailgate -Tom
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 11-23-2005, 01:58 PM   #8
cadiac
Ok it's yours then. Sending a PM -Steve
Old 11-26-2005, 01:16 PM   #9
cadiac
Bump-_-_-_ I have pics of everything -can send. Send your email in a PM -Steve
Old 12-02-2005, 03:32 AM   #10
cadiac
bump
Old 12-03-2005, 12:07 AM   #11
Green Machine
PM and Email sent -
Tom
