Old 10-29-2005, 10:43 AM   #1
modifiedGMC
headlight problem
I got my relays mounted and ready to hook to the headlights BUT I got a slight problem first. I got a 69 GMC with four headlights, halogens to be specific, when I have them on bright all is just fine. When I put them on dim the two outer light are on like they are supposed to be but not as bright as they should be and the two inner lights can be seen barely glowing when they shouldn't be. I thought bad grounds , so I took the grounds loose and cleaned them to the bare metal... Didn't help. so I tried cleaning the terminals on the sockets and bulbs... didn't help. BUT while I had one of the inner bulbs out I took a piece of wire and stuck it down in the socket on the ground side then touched it to ground with the dim lights on .... no help. Then I took that same piece of wire and touched it from the ground side of the socket over to the other side of the socket and the two dim lights got brighter like they should be and the other dim light wasn't glowing. Does any body have an idea what could cause this? should I go ahead and wire up the relays and take a 50/50 chance that it could solve the problem?
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!!
modifiedGMC is offline   Reply With Quote
Old 10-29-2005, 11:28 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: headlight problem
Strictly a guess.... bad dimmer switch?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-29-2005, 11:33 AM   #3
clay68c10
clay68c10's Avatar
It seems like you may have righ resistance somewhere, causing the current to bleed back thru where you don't want it. How are all the connections, terminals, and such? Are they all soldered? I would say one of your connections or switches is funky.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 10-29-2005, 07:58 PM   #4
modifiedGMC
That is a possibility. it's not been replaced for several years(like 8 yrs or so). I do remember back about 1997 or 98 I always ran with them on dim because the wires to the dimmer would get real hot on bright but not dim.
Old 10-29-2005, 08:20 PM   #5
GMC Jim
GMC Jim's Avatar
when the relays are wired in.... the dimmer switch controls the relays for the required hi/low beam switching. If the dimmer switch selects the hi/low function; then the deiimer switch would be Ok.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 10-29-2005, 08:20 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Well - personally, I'd prefer to find & fix the problem before adding to/changing the wiring (relays). However, if it gets too frustrating, I would probably hook up the new stuff just in case that does fix - er, I meant bypass - the problem!
- Mike -
RIP El Jay
Old 10-29-2005, 10:13 PM   #7
modifiedGMC
The dimmer switch does change them from bright to dim, it's just they have the problem mentioned above. Like I said, I've cleaned the bulb terminals, the plug terminals, both ground connections so it has to be some where in the wiring or the switch or the dimmer. I guess I could just go ahead and wire the relays in, If it still does it then I'll have to go from there. If it doesn't do it then I can say "what problem?"
Old 10-29-2005, 10:48 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Have you tried running a ground from the battery to the rad core support?
The back feeding is a classic bad ground indicator, and there is a chance that your ground strap has been torn or is missing all together.
