Old 10-31-2005, 08:14 PM   #1
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Having problems with my motor starting and staying running again?
I am having problems with starting the motor and keeping it running in my truck. Like when I go to start it, it acts like it does not want to turn over at all. My lights go somewhat dimmer then usual but not all that dim. I checked the battery and it seems to be fine. I put a new starter on there like a month ago. I was having problems with it staying running, fixed that by pulling of the carb and swapping it with another 1 I had laying around. I replaced the fuel filter and it seemed a little dirty but not bad. I had replaced the fuel pump like 6 months ago so I don't think thats a problem. I am open to any suggestions whether it might be something simple I can't think of or something I don't know about.I am hoping its something simple. Thanx for any comments.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-01-2005, 01:08 AM   #2
f.monroe
f.monroe's Avatar
Re: Having problems with my motor starting and staying running again?
Timing sounds like its too far advanced. Retard it a little and see what happens . Frank
f.monroe is offline   Reply With Quote
Old 11-01-2005, 05:06 AM   #3
Hoods69BadBowTie
Chevys Kick A$$
I went out and tried to retard it and it did not help at all.
-Later
-LATER
Old 11-01-2005, 08:38 AM   #4
88scottsdale
Sounds like your ground strap, Check the ground going to your engine.
88scottsdale is offline   Reply With Quote
Old 11-01-2005, 09:58 AM   #5
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs up Re: Having problems with my motor starting and staying running again?
Yep! thats what i was gonna suggest.
Also check your battery cables they can look fine but be corroded internally and cause high resistance.
Also check the wiring at the dist. and coil for poor connections
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 11-02-2005, 05:00 AM   #6
Hoods69BadBowTie
Chevys Kick A$$
I checked out the battery cables and they seemed good, but I quess if nothing else works I could just go get new ones. I checked all the grounds and they seemed to be all fine. Did not check the wiring at the distributar and coil connections yet though. Thanx for the suggestions and keep them coming!!
-Later
-LATER
Old 11-02-2005, 08:01 AM   #7
slimone
Hi, How long has it been since you did a good tune up on it? , check for vacumn leaks ,like around carb base plate, vac leaks can cause it to not run good. as for the starter problem ,do a draw test on battery an check all connections ,clean an tight , also take a good look at your dist cap inside of it for cracks or burns . good luck Slim
slimone is offline   Reply With Quote
Old 11-02-2005, 01:29 PM   #8
bodydropped
mine u start it and it idles weird and u go to take off it wants to die but if u baby the gas it runs good i just put a new cap and rotor but i was told its my accelator pump on my carb i have no vaccum leaks at all and im runnin a holley 4bbl
bodydropped is offline   Reply With Quote
