Old 11-03-2005, 08:24 PM   #1
chevybill
chevybill's Avatar
Question auto tranny crossmember questions
I am using a nv 3500 5 speed in my 70 c 10 with an automatic tranny crossmember. The mount holes will align really well. My question is does the end sections of the crossmember go inside the frame rails? And does the mount face toward the front of the truck and on the bottom -even with the bottom part of the frame rails? It looks like the metal side of the mount pad attaches to the transmission and then the rubber side of the mount pad goes against the crossmember. Does this sound right. I plan on using the mount just as if the tranny were an automatic.
If anyone has pics of the crossmember (automatic) mounted along with the tranny that would be great.
If I have not been clear please let me know and I will try to better explain.
thanks for all the great advice.
the crossmember i am using is from www.performanceonline.com
sorry to be so
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 11-03-2005, 08:47 PM   #2
dwaite72lnghrn
Re: auto tranny crossmember questions
To dark to take pictures but the cross-member on mine is inside between the rails. I am not sure if a C30 is the same but it should be. Mine has the angle supports from the top to the bottom. The trans mount is wide section steel to the trans and the small rubber incased section to the support.
If I am not mistaken the 4wd had it mounted to the bottom of the frame.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 11-03-2005, 10:47 PM   #3
matthufham
i just painted mine today. it goes inside the frame rails, and there should be an upper and lower flange to bolt to the frame, but my previous owner took a torch to the top flanges... so i'm left with the lower flanges. also, here's the trans mount.
matthufham is offline   Reply With Quote
Old 11-04-2005, 08:13 PM   #4
chevybill
chevybill's Avatar
thanks for the pics, any one else got some other pics?
Old 11-05-2005, 11:57 AM   #5
dwaite72lnghrn
Here are a couple of pics, th400 in a longhorn trans mount. The rear rubber mount, and a manual 4x4.
2009 HHR aqua blue
Dave & Jeanne
Old 11-07-2005, 01:31 AM   #6
shifty
Questionable
shifty's Avatar
Just for reference, Energy Suspension makes an excellent replacement tranny mount for that setup. Part number 3-1108.
http://store.summitracing.com/partde...=KeywordSearch
$20. Summit is great to deal with.
I have a picture of the xmember, but it's not quite the same (or I'd post it). The NV4500 uses a different bottom brace than the auto or 3spd.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-07-2005, 09:22 AM   #7
chevybill
chevybill's Avatar
thanks for the additional pics
Old 03-05-2014, 08:12 PM   #8
elf w/capital T
for a nv3500 swap...anyone have photos and which mount they used with any AFTERMARKET crossmembers?? and using the stock auto crossmember, which mount did you use??
elf w/capital T is offline   Reply With Quote
