Old 11-06-2005, 08:51 PM   #1
dmigura
33 12.50s on 8 or 10 in. rims
I was wondering how much difference as far as looks go for mounting 33 12.50s on 8 inch rims or 10inch rims is there. I would like to see some picks on 8 inch rims if possible
dmigura is offline   Reply With Quote
Old 11-06-2005, 09:31 PM   #2
b454rat
Re: 33 12.50s on 8 or 10 in. rims
Not a good shot, but these are 33s on 8" wheel. These tires are fat, can't imagine on 10s.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-07-2005, 02:36 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
My 33s on my burb are on 8.25" rims and they look good, I had some comparision pics awhile ago with the same 33 mounted on 8.25 and 9.75 rims, height wise no big difference and the overall width was very close, within 1/2" . I'll try and find the pics when I get home from work.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-07-2005, 02:38 PM   #4
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I have 33 12.50's on a 15x10. I didnt know you could put them on a 8??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 11-07-2005, 09:53 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Can't find the pics.
Old 11-08-2005, 10:39 PM   #6
tornado_tech
tornado_tech's Avatar
Here is a couple of pics of 33x12.5 boggers on 10" rims (front only). The rears are 33x14's. I got a set of 33X12.5 TSL's on 8" rallies but got no pictures of them. They fit the 8" rim very nice.
tornado_tech is offline   Reply With Quote
Old 11-10-2005, 10:53 PM   #7
CG
BlahBlahBlah
here is one of mine. tires are 33 12.5's im not sure what size these rims are. i know they arent 10's and they may even be smaller than 8's. i think the tire guy said it was the smallest rim he would be able to put them on.
Old 11-10-2005, 11:33 PM   #8
1976K5CHALET
1976K5CHALET's Avatar
8's will work just fine. I ran mine on rally's for years. Finally had to buy new wheels as the trails i tackle are getting harder and i tore up the rally's on some rocks...
Doug W.
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 11-13-2005, 03:17 AM   #9
super72bb
Here you go 15 x 8 inch Ralleys
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK.
My build thread:
http://67-72chevytrucks.com/vboard/s...=1#post7120181
super72bb is offline   Reply With Quote
Old 11-14-2005, 11:35 PM   #10
dmigura
Super72bb,
Sharp looking truck that is the look I want on mine. Is that a 4" lift? If so what brand, and is it rear springs or blocks.
Old 11-15-2005, 03:52 AM   #11
super72bb
That picture above is when the truck had a 4" lift. I recently purchased some new leafs for the truck and brought it down 1.5" front and back. It had 4 inch blocks in the rear, and some add aleafs to bring the front end up.
My build thread:
Old 11-30-2005, 09:52 PM   #12
RANDY COX
RANDY COX's Avatar
mine are on factory 7" wheel wish they were 8's,tires are 33x12.50.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 12-16-2005, 09:41 AM   #13
70blazerpickup
eather 8 or 10 inch wide wheels will work. i have ran both on my blazer/pickup. i have 33 12.5s on 15x10 rims and havent had any problems. i wouldnt go any wider than a 10 inch wide rim or the tire will have a hard time staying on the beed when running low pressure for wheeling.
70blazerpickup is offline   Reply With Quote
Old 12-24-2005, 02:23 AM   #14
cheyenne10
cheyenne10's Avatar
Here are some 35/12.50x15 BFG mud terrains on 8" ralleys. I see this combo sometimes.
Bob
cheyenne10 is offline   Reply With Quote
Old 12-24-2005, 10:18 AM   #15
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I found the pics I mentioned above and will post shortly!
Old 12-24-2005, 10:35 AM   #16
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Like I said 8.25 v. 9.75 rims.
Old 02-11-2006, 06:29 PM   #17
4x4Poet
8" or 8.50" is the only way to go with radial 12.50s, IMO. 10" wide rims are too wide for off road use since there is little tire bulge to protect the rim edge from rocks, logs, roots, etc. An 8" rim will also hold the bead better than 10" rims. A dedicated sand rig would be a different case, though, since flotation, alone, rules on the sand. With proper inflation, tire wear is negligible between the two widths for radials since radials don't crown like bias ply tires can.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 02-13-2006, 11:51 AM   #18
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
8 inch is fine to use with a 12.50 tire. I am about to bump up to a 37 x 12.50 MTR to run on my rallies. Right now... 35's
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-13-2006, 04:32 PM   #19
4x4Poet
Great truck and stance, 71blksuper4x4. Looks like the current lift leaves room for 37s.
