11-08-2005, 08:52 PM | #1 |
What gears are in it?
My truck is an 86 Sierra Classic. It had a 305/TH350 with air. The rear has never been out of it. I'm just curious on what gears may be in my truck.
Thanks |
11-08-2005, 10:12 PM | #2 |
Re: What gears are in it?
273:1 possibly. Check RPO sticker in your glovebox.
Curt
1970 Chevrolet Blazer 2 wheel drive - SOLD |
11-08-2005, 10:18 PM | #3 |
Right turn Clyde
Most common gears are 2.73 and 3.08 ratios. But it could of been ordered with a pretty wide list of gears to choose from if they wanted.
The RPO might help if the differential has never been removed. There is a production code on the passenger side axle tube. That will tell what it was installed from the factory with. The only real way to tell is taking the cover off and looking. Not saying that you have to do so but you wont have any doubts about what it might be anymore.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI Last edited by MylilBowTie; 11-08-2005 at 10:29 PM. |
11-09-2005, 01:08 AM | #4 |
Insert Witty Text Here
My '86 Chevy lists the rear gears as 3.08 in the glove compartment. Most seem to have the 2.73 gears, though.
Slonaker |
11-09-2005, 10:26 PM | #5 |
Thanks I'll check out the codes when I get it back from the shop.
11-09-2005, 11:36 PM | #6 | |
Slonaker |
11-10-2005, 11:08 PM | #7 |
Where did you find it? Was it on the housing? In the glove box? I get it back tomorrow.
Trucks:86 GMC C15 Longbox , 05 Silverado 4x4 The other one: 89 Mustang LX In pieces, 93 Tempo |
11-11-2005, 06:59 AM | #8 |
Right turn Clyde
RPO list should be on the driverside fender on newer 81-87 trucks and in the glove box on the inside of the door pannel 73-80. Those are loose years but thats where the RPO list should be if it has one.
Does the truck have a tachometer installled?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
11-13-2005, 08:05 PM | #9 |
THe tach will be installed when I get it back from the shop.
11-13-2005, 08:19 PM | #10 | |
Registered loser
I think you've got it backwords there. I own a 73 and the RPO list is on the Driverside Inner fender in the the engine compartment.
-Nate- There is no replacement for displacement 1996 Buick Riviera 3.8L S/C V6- DD 1973 Chevrolet Cheyenne Super C/10 LWB 454/TH350 |
11-13-2005, 10:40 PM | #11 | |
Gentleman Jim Driver
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
11-14-2005, 06:37 PM | #12 |
Mine is in the glove box. I still can't check it out.
11-14-2005, 10:13 PM | #13 | |
Slonaker |
11-16-2005, 09:07 PM | #14 |
I've got it back, it doesn't say anything. It just has a bunch codes on it. I'll jack her up and rotate the wheels and ballpark it.
