Old 11-08-2005, 10:10 PM   #1
scooby3242
scooby3242's Avatar
lowering
I have 71 c10 long bed and I am going to do a 2/4 drop. Its not a daily driver so I plan on using just springs all the way around. My question is will it cause my front tires to toe in or out if I just use springs...thanks
1973 gmc swb
scooby3242 is offline   Reply With Quote
Old 11-08-2005, 10:31 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: lowering
It will cause negative camber mainly. The wheels will lean in at the top. You'll need to add shims behind the upper control arm shafts to bring them back into spec. A 2 inch front drop will be easy to align for any decent front end alignment shop.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-11-2005, 07:46 PM   #3
modifiedGMC
Re: lowering
That's what happened to mine. I just added some shims on each side to set it out to look eye level but still got to get alignment done.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!!
modifiedGMC is offline   Reply With Quote
