Old 11-09-2005, 10:21 AM   #1
fine 67
Junior Member
steering box question
does anybody know if 73 and up steering boxes are the same as our 72 or were i can buy parts. thanks
fine 67 is offline   Reply With Quote
Old 11-09-2005, 11:34 AM   #2
truckdude239
truckdude239's Avatar
Re: steering box question
they should fit but don't hold me to it lol
Old 11-09-2005, 12:25 PM   #3
jsbgump
Gone Fishing
jsbgump's Avatar
If i remember correctly they will work up to 78. Then they changed the pitman arm design
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 11-09-2005, 12:38 PM   #4
shelby987
shelby987's Avatar
I heard up to 76 they are the same.
shelby987 is offline   Reply With Quote
Old 11-09-2005, 04:56 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
well, to be 100% acurate, they are not the same. The later ones are variable rate while the older ones are fixed rate.
However, the replacements ARE the same up to 76 or so, after that they went to metric fittings and o rings.
Old 11-09-2005, 05:08 PM   #6
Yes, all 68-87 will work, but as Andy mentioned (around 80/81 is what I remember) they went from SAE thread flared fittings on the hoses to metric thread o-ring connections. They make adapters so you can connect an SAE line to a o-ring/metric fitting and vice versa. Pitman arms only differ between power and non-power boxes. Also, as Andy mentioned the 73 and up had variable rate steering and quicker turning ratio's than our years. The 67 was way different from the others and I cannot for the life of me remember what made them so different.
Palf70Step is online now   Reply With Quote
Old 11-09-2005, 05:59 PM   #7
Joe67
67 is sold
When I bought steering gear for my project truck, it said '1976 and previous' on the receipt
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 11-10-2005, 03:49 AM   #8
jimfulco
2wd & 4wd use different ones, though.
jimfulco is offline   Reply With Quote
