Old 11-10-2005, 08:22 AM   #1
norville
Lookin for a pic with rally's or ?
Hey folks,
I'm running 6.6 or 7" rallys now with bfg at 235/75/15's. I know these tires are for 4wd's. I have a set of 8" rally's and rings ready to go, but with the current situation I'm in. I'll have to use these tires for another year or two. So does anybody have a pic of their 2wd vehicle with 8" rally's and 235's?? I also have a 2/4 drop.
Or should I just wait and drive around on these. And hope for a good deal to pop up. Right now the local shop will swap and balance for $8 a piece.
bob
1986 C10 Scottsdale
5.3, TH400
norville is offline   Reply With Quote
Old 11-10-2005, 09:15 AM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Lookin for a pic with rally's or ?
Here is the '76 2wd I had. It has the 8" Rally wheels and some larger tires on it. I am not sure about the size since I got them from a friend, but they were on his 4by Ford truck.
Hope it helps.
bigblock73 is offline   Reply With Quote
Old 11-10-2005, 09:33 AM   #3
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs up Re: Lookin for a pic with rally's or ?
This pic is from 1987 when i got the truck and kinda faraway but here it is.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 11-10-2005, 09:51 AM   #4
norville
Thanks guy's. Do you rember if the wheel/tires on the 8's filled the wells out. What I mean is, did the tires come closer to the fenders?
I have what is known locally as the "scared cat" look. thin tires tucked in way to much under the sheet fenders.
bob
1986 C10 Scottsdale
5.3, TH400
Old 11-10-2005, 10:28 AM   #5
bigblock73
yeller
bigblock73's Avatar
It filled them out well, remember, the rear track width is narrower than the front..they came this way from the factory. Here is another pic to give you a visual.
Old 11-10-2005, 01:42 PM   #6
billybob750
I had org. rally's but they were beat up, got these off an obs pickup. Very similar, they are now black with black caps, ill post new ones later
billybob750 is offline   Reply With Quote
Old 11-10-2005, 04:00 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
This is my Stock 1987 with stock size tires:
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-10-2005, 08:28 PM   #8
corn
On my 84 Im running 7's in the front & 8's in the rear. The only difference is 1/2" out & 1/2" in. I used the 7's in the front to clear my lower control arms with the drop spindles...corn
I was going to post a pic but the site wont let me right now. Ill try again later...
corn is offline   Reply With Quote
Old 11-10-2005, 09:25 PM   #9
norville
cornfed what size tire you running?
capt I could probably live with your set up. Nice truck.
thanks all for the pics.
I really can't nail down tire sizes for these trucks.
The rims I have I know were not orig to the truck say's the PO. They are narrow. That's why I got the 8"
Size (height) I really like these 235's but when you look from the back they are really tucked under there.
thanks
bob
1986 C10 Scottsdale
5.3, TH400
Old 11-10-2005, 09:34 PM   #10
Captkaos
Captkaos's Avatar
That is because the rear track width is shorter than the front.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 11-10-2005, 09:36 PM   #11
norville
HEy I just saw that BFG sells an AT 325/60/15. That's 12.9 wide and 30" tall. Ant thoughts If I just run these on the rear with my 8" rims and 235 up front. As I type I don't like the image in my brain..
bob
1986 C10 Scottsdale
5.3, TH400
Old 11-10-2005, 11:34 PM   #12
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I would not run over a 275/60/15 on an 8 inch wheel. Anything wider looks odd. A tire as wide as you mentioned might not even be safe on an 8 inch wheel.
I like the look of a 255/70/15 or a 275/60/15 on an 8 incher. You can see what the 255/70/15 tires look like on mine, lowered 2.5 inches in the front, on the pic at the top of my website.
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 11-10-2005, 11:38 PM   #13
corn
Im using 225/70 on the front & 275/60 on the rear...
Old 11-11-2005, 12:51 AM   #14
Prerunner1982
Prerunner1982's Avatar
here it is with 235/75/r15s
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
