Old 11-11-2005, 04:08 PM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
350 turbo vacume line?
I just purchase a steel hard vacume line for my turbo 350 trans.
I think I figured out how it attaches, but was wondering if anyone had some picture on the hard line installed. Thanks
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 11-11-2005, 06:35 PM   #2
john
member #16
john's Avatar
Re: 350 turbo vacume line?
Does your line have a clip on it to bolt to bellhousing bolt? Mine does and it can only go in one place. If it doesn't hook both ends up and fasten to bellhousing. It should end by a bolt hole.
Okay that looks right, I hadnt seen the second pic. John
john is offline   Reply With Quote
Old 11-11-2005, 06:40 PM   #3
4tiresngas
An American Soldier
4tiresngas's Avatar
Yep, that's correct. I just bought one off a truck in a salvage yard after I pulled the cab off. I went ahaed and got the xmsn dip stick assembly as well since it bolted to the bell housing with the modulator line. The dip stick the PO installed was zipped tied to a wiring loom. I thought this setup was much better.
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 11-11-2005, 07:22 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Looks right to me. It attaches to a fitting in the manifold vacuum port, looks like you have a piece of paper stuffed in that hole. If you don't have the fitting, you might have to go to the hardware store and buy something. If you have power brakes, you need a tap to the other side.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 11-11-2005, 09:48 PM   #5
BOSS
Just here to help
BOSS's Avatar
does this work the kickdown also?Just wondering because mine isnt hooked up and i dont have kickdown when i get into it.If it does where can i hook it up to?Anywhere that has vac?Thanx
Support our site
Norwood Survivor
BOSS is offline   Reply With Quote
Old 11-12-2005, 10:57 AM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
Kickdowns are usually electrical. 71-72 used a switch on the accelerator pedal, earlier used a carb mount switch.
Fred
Old 11-12-2005, 11:11 AM   #7
willow72
willow72's Avatar
what?eletrical?really?
willow72 is offline   Reply With Quote
Old 11-12-2005, 12:37 PM   #8
53burb
53burb's Avatar
350 trannys were cable actuated & 400s are electric...
53burb is offline   Reply With Quote
Old 11-12-2005, 01:22 PM   #9
76bonanza
76bonanza's Avatar
right 53burb is right th350 uses a detent cable and the 400 uses electric kickdown.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
