Old 09-03-2002, 12:04 AM   #1
diehardrider
KEEP IT PINNED
oil baffle
Does any one know of any oil baffles for valve covers. They have them in summit but are 23 bucks a piece.
RYAN KING
71 swb 4x4
diehardrider is offline   Reply With Quote
Old 09-03-2002, 12:08 AM   #2
BUXMAN66
go bucks!
it's not hard to make some yourself outta sheet metal,if you have access to any that is.i made some for my mickey thompson's i have.
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 09-03-2002, 08:30 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Arrow
You might be able to remove one from a junker. I think these are spot welded in. $23 dollars could be better spent elsewhere IMO.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 09-03-2002, 10:17 PM   #4
diehardrider
KEEP IT PINNED
thanks for the info.
IM trying to look into getting some fabbed or fabbing some?
Any body have ideas?
How would i go about attching them?
RYAN KING
71 swb 4x4
Old 09-04-2002, 02:20 AM   #5
BUXMAN66
go bucks!
one thing you have to look for is that you have bosses on either side of your hole location(oil fill, oil breather, or pcv location) once you drill your hole for these applications look for a suitable location on either side of the hole to drill your small sheet metal screws into thus forming a "shroud" or baffle over the larger hole to keep from oil splashing into your breather,pcv or whatever.mine stands about .500" tall x1.125"x1.125" square.leave a .250" lip on either side and drill a #29-#30 drill hole into the sheetmetal lip to attach to v.c.underside.make sure you have rocker clearance(standard on smblk. is 1.5"rocker lift,i believe)also, put a piece of tape on your drill bit so you know how deep to go w/o going thru the top of your v.c.'scouse if you have chrome v.c.'s you cant do any of this becuz the metal is too thin,in that case all you can do is spot weld them in or splurge for some new 'uns w/ oil baffle's already attached underneath.good luck!
Old 09-04-2002, 03:31 PM   #6
diehardrider
KEEP IT PINNED
I have a pcv baffle already it isnt the normal flat sheetmetal type.
It use a piece of tubing with the end capped off and hole.
This is the one that comes with the valver covers.
I do have welded alumium valve cover but i dont feel comfortable drill into the,
I might take it to a stainless shop and see if they can tack it or something.
RYAN KING
71 swb 4x4
