Old 11-13-2005, 09:21 PM   #1
3qtrtontarrer
top chop help
thinking about a 3-4 inch top chop on my 70, anyone got pics or best ideas as where to make the cut on this and does the windshield need to be laid back. thanks
3qtrtontarrer is offline   Reply With Quote
Old 11-13-2005, 09:35 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: top chop help
4" chop top picks in my signature.... if you pick up a copy of HOW TO CHOP TOPS, written by Tex Smith, you will see several examples of chop tops on the 67-72. I chose to lay the sheild back on mine, but you can do a "straight chop", that sections the top intp 4 pcs.....just depends on what you like L woops!...... http://community.webshots.com/user/hotrodhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-13-2005, 09:36 PM   #3
roj2323
Re: top chop help
the windsheild doesn't have to be laid back if you extend the length of the roof from front to back.
the only peice of advice i can give you on this subject:
bracethe cab for twisting on all axis. when your done brace it some more. you can never have enough bracing when you chop a top.
ondrew
roj2323 is offline   Reply With Quote
Old 11-13-2005, 09:48 PM   #4
crazy longhorn
Re: top chop help
ondrew
A brace across ea door opening (front to rear) is all i used, & I had no problems......a little extra bracing falls into the "cant hurt a d@mn thing" tho...... L
Old 11-13-2005, 10:23 PM   #5
...jasper...
Re: top chop help
So Crazy ! Who cut your whindshield ? I chopped a 67 3 inches, and cut all the glass,except the windshield. Did you cut it ? I was told you could like tape it off with something like duck tape. Several layers. Just leaving were you wanta cut. Blast both sides with a sand blaster,then pour lighter fluid on it to burn the plastic. After that take it to a glass shop,or some were that has a belt sander to smooth the edge. But I am not sure you can do this. I might try. What did you do ? The windshield is all I got left to do other then painting.
...jasper... is offline   Reply With Quote
Old 11-13-2005, 11:22 PM   #6
crazy longhorn
Re: top chop help
Yes, I cut the sheild.....it took about 6 hrs to get it down to size, then the belt sander went to work. I cut the sheild with a glass cutter, a strip at a time. just like any saftey sheet, you cut 1 side, then the other......the only difference is that you are cutting a little at a time . the glass is taken off in cresent pcs,(about 2 -3" long,& 1" wide) starting from the backside on the 1st cut. I had about 10yrs in glass work, so the flat stuff was no problem......the curved saftey sheet takes a lot of patience to do tho! Its all explained in the HOW TO CHOP TOPS book, as well as many pics on the 67-72 trucks & many others...... L
Old 11-13-2005, 11:28 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: top chop help
While I agree that bracing can't hurt... If the cab is on the frame, there should be no problems with sagging since it is only like 5 feet from front to back and not a main structure point.
Old 11-15-2005, 06:48 AM   #8
3qtrtontarrer
Re: top chop help
thanks for the help guys ill give it a shot
Old 11-15-2005, 08:34 AM   #9
FormerMember
Re: top chop help
Let me know how it goes. Of course, I can help if needed. No skill, but I have hands.
FormerMember is offline   Reply With Quote
Old 11-15-2005, 03:42 PM   #10
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: top chop help
A little something I "found" might help you a long.
http://www.hotrodsbyhg.com/current_p...c10_kustom.htm
sneakysnake is offline   Reply With Quote
Old 11-19-2005, 06:36 AM   #11
3qtrtontarrer
Re: top chop help
thanks snake that helps alot
Old 11-19-2005, 07:57 AM   #12
LONGHAIR
Re: top chop help
One thing I noticed, in what appears to be a very good job, is in the picture of the frenched antenna. It shows the welder's ground clamp attached to the door, while the work is being done on the cab corner. Don't do this. It forces the welding to get it's ground across the hinge pins. This is not only hard on the pins themselves (it can cause pitting from the arcing) but it could bite you if it momentarily lost ground because the door moved.
LONGHAIR is offline   Reply With Quote
Old 11-19-2005, 09:40 AM   #13
3qtrtontarrer
Re: top chop help
very interesting longhair thanks
Old 11-19-2005, 09:57 AM   #14
FormerMember
Re: top chop help
Heh, yuo can practice with the 68 cab then.
BTW, the roof and windshield frame is perfect on that one...
Old 11-19-2005, 01:54 PM   #15
chopped 71
Re: top chop help
HERE IS MINE THE ROOF WAS CUT IN 4 PIECES AND STRECHED. ALL THE GLASS WAS MADE WITH TEMPLETE AND THE WINDSHIELD WAS CUT VERY CAREFULLY. IT TURNED OUT GOOD BUT I DON'T THING I WOULD DO IT AGAIN.IT,S BEEN 9YRS SINCE WE CHOPPED AND PAINTED IT ONLY ONE SMALL ROCK CHIP IN THE WINDOW. HAPPEND FIST WEEK I WAS DONE.
chopped 71 is offline   Reply With Quote
Old 11-19-2005, 01:57 PM   #16
chopped 71
Re: top chop help
Old 12-01-2005, 11:09 PM   #17
chopped 71
Re: top chop help
The Coler Is A Stock Gm Yellow Used In 70-72 On Corvetes.the Same Coler Was Used In The 50's,i Still Uave Paint Some Were I'll Look For A Number.
Old 12-11-2005, 11:08 PM   #18
bigblockc10
bigblockc10's Avatar
Re: top chop help
Thanks for the info.
That color is so perfect.
1970 C10 Stepside (soon to be a 68
w/PS/PB/S&W back-half narrowed F**D 9inch w/Discs)
66 427/435 corvette motor (hopefully 871 Blower)
66 M21 4 speed (swapped in a built TH400)
31/16.5/15 Mickeys (soon to be 29.5X18.5X15 MT)
1972 C10 Stepside Pro-Street
1988 bed
3" Top Chop
Custom Red Pearl paint w/overlapping Ghost Flames
P/S P/W P/B P/DL P/door open
Everything Shaved
Frenched antenna
461CI BBC BDS Blower 1100 Dynoed HP
TH400 Super Heavy Duty
Full Back-Half
Narrowed 12 Bolt 4:10
bigblockc10 is offline   Reply With Quote
