![]() Join Date: Mar 2003
any dual shock pic's?
Anyone running dual shocks, please post a few pic's and let me know what brand you are running...thanks.
Premium Level Member
Re: any dual shock pic's?
dual's = rough ride. I had them on my 77 when I first bought it..ouch. No need for them. One shock of good quality is more than enough in my opinion.
Most people run them just for looks, but I'm sure they sacrifice ride quality ![]()
69 K5 CST stock- 350, 4speed ![]() 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, |
![]() Join Date: May 2004
I believe some people drill holes in the second shock to relieve the gas pressure to make it useless and not hurt the ride. It would only be for looks after that.
![]() Join Date: Feb 2000
You can actually buy shocks that are designed to be used as a pair. If you use a pair that aren't designed to be used as a pair, you definitely get a rough ride.
I don't recall seeing any shots of a first gen with dual shocks that I could dig up for you.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
SKINNY TIRES RULE!
I read on CK5.com once, that someone was using ford f150 shock towers to run dual shocks. I don't know if they uses an aftermarket shock hoop or if it was a stock f150 setup.
Check the forums on CK5.com and Pirate4x4.com.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I don't run dual shocks but my Blazer has the bracket for it.
On the left side of the pic. the inner bracket is the factory piece and the outer one is the dealer installed one.It's welded on. ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
The LuvShack Garage
Interesting
PROJECT 7DEUCE
![]() Join Date: Dec 2002
That dual shock set-up shuold be pretty easy to dupilcate. Bobby are those the tranny cooler lines on the outside of the frame rail???
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
SKINNY TIRES RULE!
The lines are probably fuel lines for his TPI system.
Here's a couple of pics of the factory setup used in about 85-87 or so.
![]() ![]() Bob
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
#11 | |
When I redid my trans lines I didn't want to mess around trying to get them to fit on the inside rail...so I ran them on the outside. Made up some stainless covered rubber lines to join the hard lines between body panels(frame to rad. core,frame to trans.)
#12 | |
