11-19-2005, 03:41 AM | #1 |
Need clarification re: my tilt column for sale
I have a board member interested in my column, but he is concerned it might be a converted van unit because of the clipped plug wires. To my knowledge the stubby splined end would indicate a true truck tilt, and I see no evidence of safety switch relocation, but I thought I would see what you board members thought. What do I have?? Thanks.
"You can take the man out of PA, but you can't take PA out of the man" |
11-19-2005, 06:56 AM | #2 |
its all about the +6 inches
Re: Need clarification re: my tilt column for sale
looks like the real deal.
The harness is probably fropm some one installing a replacement turn signal switch and not having an adapter to use. |
11-19-2005, 08:20 AM | #3 |
Looks right to me also.....The van tilts have the neutral switch further up on the column. At least mine did.......
1997 GMC Sierra Ext 1965 Mustang |
11-19-2005, 09:21 AM | #4 |
You`re right,it`s a truck unit with questionable wiring.As you described in your listing.
11-19-2005, 01:02 PM | #5 |
Gone Fishing
Looks like a real truck one to me.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
11-19-2005, 01:03 PM | #6 |
Thanks everyone.
11-19-2005, 01:34 PM | #7 |
Take a look at the neutral safety switch and see how its hooked into the switch..if its a tab thats been folded back from the original inner tube into a grooved switch tab ...well then its original. It looks original to me from what I see here. Rod
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
11-19-2005, 04:18 PM | #8 |
My truck's original column had the hack-n-tap done to the harness. Someone replaced the column switch but couldn't find the half-moon style plug, so they hacked it. That's what you have there.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
11-19-2005, 08:59 PM | #9 |
Some people just dont know how to get the switch plug through the column..so they hack it and attach it after...thats what I see there. So I agree with 69TowRig on that.
11-19-2005, 09:35 PM | #10 |
If you ever have seen the van and truck tilts together would never forget the differences. Like said above....The short splined shaft is a truck and the position of the neutral safety switch is also a truck. Maybe we need to get someone who has a pic of the two side by side and keep it posted in a sticky. Heck there might be a pic in the FAQs
P.S. I just installed a van tilt in my truck a couple of weeks ago so I know the one you have there is a truck!
For every person with a spark of genius, There are a hundred with ignition trouble. 70 Short/Step Last edited by 70short/step; 11-19-2005 at 09:38 PM. |
11-19-2005, 09:45 PM | #11 |
"Trucks with Class"
Left to right:
Van/Van with N switch in PU position/real 71-2 PU. |
11-20-2005, 03:23 AM | #12 |
Hey, that is a good pic for comparison. Thanks again for all the help guys.
