11-19-2005, 11:44 AM | #1 |
Tilt indicator light wire
Where exactly is the gray wire from the the PRNDL light supposed to plug into on a 71 chevy with a tilt colum? Did it originall plug directly into the fuse panal?
Thanks Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
11-19-2005, 12:02 PM | #2 |
Re: Tilt indicator light wire
No. Original was a fiber opic cable that plugged into a light socket on dash light holder. Just splice it into a gray wire in harness that is easy to get to.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
11-19-2005, 12:57 PM | #3 |
No, tilts didn't use the fiber optic cable, we are talking about a tilt column here. I would like to know where it is supposed to go, I know I can splice it in under the dash, I want it to be hooked up like they were originally.
11-19-2005, 03:55 PM | #4 | |||
Union Electrician
it goes to the fuse panel and hooks up to one of the spots that say ignition hot, that way it comes on everytime you turn the truck on.
Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
11-19-2005, 07:43 PM | #5 |
member #16
Take a test light and test the fuse panel. There is a single post that will turn on with headlight sw. edit it plugs in where it says cluster feed..... John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 11-19-2005 at 07:57 PM. |
11-24-2005, 12:42 AM | #6 |
Anyone have a picture of the tilt indicator light? Mine's missing. Does it have a lens, or a bulb, or what?
jku Cornville, Maine 68 C10 burb 42 Willys MB 46 Dodge WF-32 1.5 ton 53 & 56 Olds' 60 Cadillac 22 Dodge Brothers |
11-24-2005, 12:27 PM | #7 |
its all about the +6 inches
John has it right... cluster feed. That'll turn it on and dim it with the dash lights. Good place for your aftermarket guages to get lit up from too.
11-24-2005, 07:56 PM | #8 |
Thanks everyone, I have tied it into the cluster feed terminal with a splitter/pigtail.
