11-20-2005, 07:19 PM | #1 |
another stop and stall question
when ever i slow down (an stop light) i push th clucth in and when the motor idiles down it will stall its fine if i rolling down the road runs good but when i stop or sitting still its runs rough and stops. i don't know where the choke is only thing i see an metal pipe running down to the exhast manfoiled the pipe comes off the side of the carb i tried to adjust the linkage but its adjusted all the way out i have the stock 2 barrel carb any ideas thanks in advance
11-20-2005, 08:19 PM | #2 |
Designated A-hole!
Re: another stop and stall question
Check for vacuum leaks, sounds like you are sucking air somewhere.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
11-21-2005, 12:07 AM | #3 |
thanks i'll do that in the morning
11-21-2005, 09:46 PM | #4 |
check this morning i can't find any leaks any other ideas?
11-21-2005, 09:54 PM | #5 |
my 67 c10 292 3spd was doing this. It would die at stop lights, driving down the road and putting the clutch in (idle drops) or sitting in the drive way after warming up if you pulled the brake pedal or carb linkage closed the engine would die. I screwed with the carb, replaced the fuel pump, pulled the balancer and checked the timing marks. Finally I pulled the distributer (remote mounted coil electronic Hei, big cap) and put the old worn out points distributer back in. Runs much better than it was. Currently has not died at idle again
I still need to find a better solution than the old points but the low compression in the #4 cylinder is more of a concern. |
11-21-2005, 09:59 PM | #6 |
Is your choke plate closed when it dies ??
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
11-21-2005, 10:02 PM | #7 |
i have no clue all i know its an point truck i will get someone out side to look at the carb when it running to see. but i don't know what kinda of choke it has because the right side of carb has an metal pipe that comes out and runs down to the exhaust manifold
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 11-21-2005 at 10:04 PM. |
