Old 11-21-2005, 11:29 PM   #1
djtlaz
Differential Cleaning
I'm getting ready to put my 4" lift on my truck. But before I did that I was going to redo the whole front steering. So since I was going to take differential out I wanted to clean it and paint it. What is the best to use. I will use a wire wheel but wanted to put something on it to eat through some of the crud. Many people have suggested oven cleaner. What do you guys recommend?
djtlaz is offline   Reply With Quote
Old 11-21-2005, 11:46 PM   #2
BowTieMan
BowTieMan's Avatar
Re: Differential Cleaning
I just use what my dad has used to clean things for years. Some gas and a wire brush type thing with a long handle. lol not sure of the exact name but that always gets things clean.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 11-21-2005, 11:48 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I used some oven cleaner and water outta the hose and then got a wire wheel for my disk grinder and finished it up with that then shot on some paint.. Heres a pic..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-21-2005, 11:50 PM   #4
cdowns
cdowns's Avatar
oven cleaner is a good thing to loosen up the crud//it also has the advantage of not exploding like gas does
Old 11-21-2005, 11:53 PM   #5
djtlaz
When getting all the crud off and ready to paint. Does it require to primer it. Or can I just spray the paint on.
Old 11-22-2005, 11:34 AM   #6
chevyfarmer
chevyfarmer's Avatar
Primer will help it stick better. Paint is really designed to stick to primer and primer is designed to stick metal. However, I have painted tons of things without priming them. It will really depend on how much time and $ you want to put into it. Once you have it clean you might want to wipe it down with wax and grease remover (available @ any automotive paint store). This will help remove any oil and residue and promote adhesion.
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
