Old 11-25-2005, 11:53 AM   #1
shelby987
shelby987's Avatar
saginaw 3 spd to 4 spd
I was wondering if anyone here could tell me.....will this transmission bolt into my 4x4 in place of my current saginaw 3 spd?
http://cgi.ebay.com/ebaymotors/Sagin...QQcmdZViewItem
I currently have a column shifter, and wanted to know if it would be possible to put in a 4 spd, using reverse the reverse location as 1st gear, and so on....then mounting possibly a floor lever to shift into reverse.....and thoughts?
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 11-25-2005, 12:19 PM   #2
truckdude239
truckdude239's Avatar
Re: saginaw 3 spd to 4 spd
looks like it should bolt right up
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 11-25-2005, 01:03 PM   #3
crazy longhorn
Fabricate till you "puke"
Thats a direct bolt in for a 2WD truck.....but I think not for the 4x4. if you have a sag 3spd bolted to your transfer case,you can use the tailshaft from the 3 spd, & adapter mated to the 4spd to set it up tho.... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
