11-25-2005, 04:48 PM | #1 |
Project92 SWB stepside
Waste oil heat
I am looking for a long term low cost heating solution for my garage. I have found a few ideas like the waste oil burners or heat pumps. I beleive a heat pump I could get air conditoning unit with it also. That would kill 2 birds with one stone in itself. What do you guys have or know of?? Its cold out in that garage!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
11-25-2005, 04:51 PM | #2 |
its all about the +6 inches
Re: Waste oil heat
Look at the waste oil thing very carefully.
We use it at the shop, even though it does save thousands of dollars a season, it has been 5 years and we are just seeing the profits. Very expensive to set up, maintain, and in all reality, you'll be needing to buy used motor oil since you could never produce as much as is needed. Plis the compressor will have to be on when ever the heat is on.... I can't see it workin in a home shop. |
11-25-2005, 05:10 PM | #3 |
Re: Waste oil heat
The heat pump idea seems to be more reasonable as far as the $$$ go. Anyone have a heat/air pump??
11-26-2005, 03:09 AM | #4 |
someday it will be done!
Re: Waste oil heat
The thing that bugs me about this subject is that there is such pressure to reduce pollution by any means possible,yet the powers that be have no problem whatsoever charging astronomical fees for the "green" alternatives.If the price of natural gas wasn't so high,this thread wouldn't even be necessary!
That said.....I'm watchin this one for replies
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
11-26-2005, 03:13 AM | #5 | |
Re: Waste oil heat
11-26-2005, 07:47 AM | #6 |
Watch out for your cornhole !
Re: Waste oil heat
I've been seeing about 2k dollars buy in price to get a waste oil system going in your shop. I just built a 30x40, and I'm really considering it.
It looks like it will burn about 4/5 of a gallon per hour of usage. All my drivers are diesels, so they take 3 gallons each oil change, and my wife owns a big construction company with dozens of tractors and dumptrucks, so I think I can get enough oil to support it. Like Andy said, they do use shop air also. Basically, since Propane prices has near doubled, it's looking more attractive all the time.
11-26-2005, 10:57 AM | #7 |
I am a Referee of life.
Re: Waste oil heat
My B-I-L used one in his tranny shop for years.He built the first one and it worked but was somewhat problematic.I think he got it to work pretty well after the first year.A few years later when he needed to replace it (the drum rusted/burned out)he bought one.It worked great and had few problems as long as he filtered the fuel.Of course he had tons of used tranny fluid to run in it so fuel was no prob.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-26-2005, 05:14 PM | #8 |
Re: Waste oil heat
I wonder if one is made that would connect to a boiler. I am getting set up for hot water (actually glycol) heat, but I'm undecided on how to heat the fluid. I have 2 propane fired water heaters, but like has been said, the price of propane is going up along with everything else. I also wonder just how much oil you really would have to buy. It seems like everyone is looking for a place to get rid of the stuff.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
11-26-2005, 05:47 PM | #9 |
Re: Waste oil heat
I just bought some Kersosene today at $3.69 a gallon. OUCH
11-27-2005, 09:49 PM | #10 |
Re: Waste oil heat
The waste oil heaters are good, but they require alot of maintenace. We had 2 huge units in a shop I worked in. The biggest headache was they required adjusting the pumps to compensate for colder weather. Many aday we were freezing until we fixed the pressures and shop warmed up. We used kerosene to thin it when it was cold and we didn't have much oil. It required major adjustments. You have to clean them thouroughly at least once a year or they don't work. Also when the do break, few people work on them and parts can sometimes be a pain. When they are adjusted right they have almost no emmisions, but when they get out of wack they spew nasty black smoke(read oily). Prob wouldn't want one myself unless it was away from buildings/cars.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
11-27-2005, 09:50 PM | #11 |
Re: Waste oil heat
Yeah the heat pump idea is looking better!!
11-28-2005, 12:15 AM | #12 |
Re: Waste oil heat
The latest thing here is corn burners. You buy a 50 or 100 bushell hopper and a corn burner with an auto/auger feeder and it will heat a 3000 square foot home on 3/4 bushell a day. You could buy all the corn in this county from any farmer for $2.50 a bushell.( for that price they would probably deliver )
If I had a rural place I'd put in a corn burner and heat water/glycol and run it in the floors |
11-28-2005, 03:28 AM | #13 |
Re: Waste oil heat
Northern Tool Sells One Called An Elimnator 3000 or something like that for around 2-3k i dont really recall the specs.
Personally I used a Wood Burning Stove Made From 20" Rims Burn Scrap wood and anything else i can find There is a local pallet manufactureing company that give away stacks of cut off pieces of oak May be something similar in other places They even load it with a fork lift as much as you want. I also have an Oil Drip Installed On My Stove With a 30 Lb Freon Tank For A Resivoir And A Ball Valve to regulate the drip Puts out plenty of heat as long as theres a bed of coals to drip oil on |
